Question about Kyocera Mita Office Equipment & Supplies
Got a KM 6330 with C640 error code. Manual leads to main pcb and/or power supply. I Have switched both main pcb's and power supply with working machine and code stays. Have cleared 906 as well. no change. any idea's please
SOURCE: Kyocera KM 3035 copier display panel says:
Check the interlock at the front of the internal finisher where the inner tray locks in. sometimes the connection isn't solid and can lead to this exact problem. 906ing the machine won't fix it as there is essentially nothing wrong with the finisher.
Posted on Mar 11, 2011
checkitright
  • 1362 Answers
SOURCE: Kyocera KM-6330 ( c-6020)
Did you check the thermofuse? are you getting continuity from the fuser lamps?
Posted on Oct 31, 2007
SOURCE: ERROR CODE E000100-0001
I did this and it did not solve the problem. What can I do?
Posted on Jun 13, 2008
  • 5 Answers
SOURCE: ERROR CODE SC101
Definition Symptom Possible Cause
SC101 Exposure Lamp Error
The scanner has scanned the white
plate, but cannot detect the white level.
• Defective exposure lamp
• Defective exposure lamp stabilizer
• Defective exposure lamp connector
• Unclean scanner mirror
• Scanner mirror out of position
• Defective SBU board
• Defective SBU connector
• Lens block out of position
• Incorrect position or width of white
plate scanning (�� SP4-015
Posted on Mar 14, 2009
  • 241 Answers
SOURCE: Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
Posted on Jun 09, 2010
Image runner getting this error code (E261-0000) / how do i fix it
Code
E261-0000
Description
The intervals of zero-cross signals deviate from the tolerance range while the fixing heater is supplied with power
Causes
The wiring is faulty (short circuit, open circuit). The main power supply PCB is faulty. The DC controller PCB is faulty.
Remedy
1. Connectors Are the connector J205 on the main power supply PCB and the connector J308B on the DC controller PCB securely connected? (zero-cross signal: J205-7 <-> J308B-1) NO: Connect the connectors securely. 2. Main power supply PCB, Main controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.?
Best Regards
Jul 24, 2016 | Office Equipment & Supplies
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
Cannon-3300 Copier Error code E000-0000 rectify the problem
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Jan 18, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
It has stopped working and is displaying a flashing AP but it's full of paper. Sometimes it also flashes error code 400 any ideas?
Chek toner for Flashing AP
Error C400 polygon motor synchronization problem
1. poor contact in polygon motor connector terminals
2. defective polygon motor
3. defective power supply board or main pcb
Apr 18, 2010 | Kyocera KM-1510 Copier
Error code E000803-000
that mean low power or The 24V output from the composite main power supply PCB is absent for 1 sec or more.
Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
PCB (J300)?
Feb 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Km1505 digital copier machine
I would suggest that you confirm proper fixing heater supply turn on from Power source PCB to fixing unit if possible. Or replace it with a known good one (part# 2A1280551). If you are getting a low AC voltage reading at the heaters when they should be heating you may have a defective Triac or relay on the power PCB. If that is all OK you are probably looking at the main PCB as a source of the problem as it sends turn on signals to the power PCB.
Dec 29, 2007 | Office Equipment & Supplies
IR 2000
Fuser error probally needs fuser replaced and the reset as below
try this
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
or this is explaination of the error and required fix from service manual.
E0000000
Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
Caution To reset the error, execute the following in service mode:
Action
1. Connector
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
supply PCB.
PCB.
Nov 18, 2007 | Office Equipment & Supplies
Oct 27, 2007 | Office Equipment & Supplies
142 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
