Question about Electric Lawn Mower
Inbuilt breaker disconnects power to the motor, motor is cool.
Electric corded mower works well except its thermal coupler?? keeps shutting the machine down even under a light load. This is a thin white pin on the switch that pops up when the machine is overheated, supposedly. Could it be so worn it disconnects too easily and can it be replace easily? Blades sharp and underbody clean. Thank you
  • 63 Answers
If it is tripping as much as you say, it needs to be replaced..... just as a breaker in your house, if it starts popping all the time and there is no problem you have to replace it. replacing it is not all that hard, if you are handy with tools. finding it maybe a little harder. you can check at local mower repair shops. with it unplugged, make sure the blade turns without binding also.
Posted on Feb 03, 2010
Testimonial: "very helpful "
Why does our Bosch 32R mower keep cutting out?
is this a corded mower or battery operated . if corded your cord might need replaced
Feb 13, 2016 | Office Equipment & Supplies
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Outlets not working all fuses are good
120-
VOLT
AC
SYSTEM
The following electrical components (if so equipped) will only operate when your
RV is connected to shore power: 120 to
12-volt power converter, air conditioner,
120-volt refrigerator, microwave oven, television(s), fireplace and appliances
plugged into convenience receptacles.
SECTION 6 - ELECTRICAL SYSTEM JAYCO TOWABLE
6-2
120-
VOLT
CIRCUIT
BREAKERS
The 120-volt AC circuit breakers located in
side the main load center protect all
120-volt wiring and components in the RV fr
om circuit overloads and short circuits.
Should a circuit overload or short circui
t occur the circuit breaker protecting the
affected circuit will "trip" preventing the flow of electricity through that circuit.
If a circuit breaker trips, shut "off"
the appliance on that circuit (i.e., power
converter etc.) and allow the circuit breaker to cool down for a brief period of time.
After the cooling down period, reset the circuit breaker by moving its lever "off" and
then back to the "on" position. If the circuit breaker re-trips or frequently trips,
contact your dealer to have the electrical problem diagnosed and repaired.
A circuit breaker identification label is permanently attached to the inside surface
of the 120-volt load center.
Maintenance and Replacement
At the beginning of camping season, inspect the circuit breakers and replace as
needed. Test by turning each circuit breaker "off" and back "on". Circuit breakers
are wearable parts and must be replaced
as needed, as part of your RV
maintenance. If you have any questions, consult your dealer.
Please contact your dealer for repair assistance when replacing circuit breakers.
CONVERTER
The power converter converts 120-volt AC power to useable 12-volt DC power
when the shore power cord is connected to an external power source.
The converter has a built-in protective thermal breaker that will shut it down should
overheating occur. Overheating can be
caused by operating the converter above
its maximum power output for an extended period of time, or by an obstruction to
its ventilation air flow. To reduce converter heat build keep unnecessary 12-volt
lights and motors turned "off"
Keep the converter cooling fins and fan clear of
obstructions.
Inspection and maintenance
If the 12-volt power converter is not working (auxiliary battery not being charged)
check the reverse polarity fuse(s) in the converter fuse panel.
There are no
customer serviceable parts inside the converter case and the
manufacturer's warranty will be void if
the case has been removed
. If you
have further concerns contact your dealer.
Nov 16, 2014 | Jayco 2013 Jay Flight Swift 264BH
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt cool, not clogged
Sounds like electric motor has gone bad. If you can get past the switch and put a tester on and see if there is any power there that would tell whether your switch has gone bad. I had a new electric motor go bad after ten minutes use. I ended up replacing it.
Sep 28, 2014 | Garden
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
My story is the same. I have an MM600, replaced switch, and still trips breaker in variety of configurations. I have tried both of the relevant configs recommended on this site, and no luck. Is there...
As you know a breaker tripping is a result of a direct short inside the electrical circuity of your mower.
That short can be anywhere from just beyond the switch all the was down to the winding in the motor.
There are 2 switches Item 3 and Item 7 of this link:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/MM600_TYPE_1
Places for a short are the power wire from the switch to the motor connection. (Item 28 of link)
A broken motor brush where the carbon brush has broken off and the metal from the spring is now touching wither the motor chassis or across multiple segments of the armature.
Check items 46, 47, 48, 48 this link for damage:
Also check Item 80 Brush of the above link (picture below link
http://www.toolpartsdirect.com/cgi-bin/parttools.cgi/242273-00
A bearing in the motor can have failed allowing the armature Item 65 of link to drag on the stator item 70 of link and cause a stator short where the armature damaged the stator winding.
The above items are all things that can cause your problem. It will take a multi-meter and some resistance checks of the circuit to isolate exactly where the short is.
I would connect the meter across the 2 power cord terminals i.e unplugged and simulate mower use then start disconnecting wires one at a time working my way backward from the motor to see when the short disappeared. If the short is in the motor... then we are back to all of the times above except the cord and switches. The all have to be isolated and checked out.
Kelly
May 02, 2010 | Black & Decker 19" Electric Lawnhog...
My corded 18" corded electric motor does not run although outlet and cord ok - mower is 2 years old and used once a month
There should be what is called a "thermal breaker" on this. It should either re-set itself or you may have to push a little button down by the motor.
Please let me know, we repair this kind of equipment.
Feb 10, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Thermal occurrence, the computer keeps shutting down and sending a message of thermal occurrence.
It is very likely that your computer has excessive dust keeping the fans from distributing air for cooling within the unit. It can also be an issue with the power supply fan not working. First, verify the fan is turning properly. If not, replace the power supply. The same thing can be true for the cooling fan for the processor. Check to make sure it is running. To do so will require you to look at it with the side cover off and computer running thus posing a RISK of ELECTRICAL SHOCK. UNLESS YOU ARE CLEARLY VERSED IN HOW TO DO THIS, I ADVISE TAKING IT TO A COMPUTER STORE.
If these two fans are working properly, cleaning the dust inside the computer is the next step.
Disconnect electrical cord from the computer, ground yourself by touching the case to eliminate static electricity, remove side cover from the computer.
Using "canned air" widely available at computer or office supply stores, blow out the dust from the power supply and interior of the computer.
Oct 02, 2009 | Dell Computers & Internet
Electric Lawn Mower Logo
710 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
