Question about Intel D865GBF Motherboard
My CPU sounds too much.why? - Intel D865GBF Motherboard
    President:
  • 2,017 Answers
Make sure you have proper cooling and cpu is not gerating too much heat. you can try with changing the power cord.
Have a nice day and do not forget to rate please...!
Posted on Feb 03, 2010
Windows vista My built-in monitor does not sound, I tested w other CPU and it sound
You have to plug the speakers into the computer to get sound out of them. The CPU has nothing to do with the speakers, Also your monitor does not have inbuilt speakers(according to the manufacturers website.)
Feb 27, 2013 | HP W2207h 22" Wide Lcd Flat Panel Monitor...
Shut down during boot
Sounds like a cpu overheat situation. Check the cpu temps in the bios and compare the temps with the maximum operating temp of your particular cpu. It might need better/or/new cpu thermal paste applied to your cpu, and also check that your cpu fan is running and locked down tight (and not loose)
Nov 22, 2011 | PC Chips P23G Motherboard
The system is consistently in power saver mode and therefore nothing is displayed on the monitor.There are beeping sounds from CPU when power is put on.
Good day..!!Since there is beeping sounds of your cpu,i think its better to check the memory of your cpu,and try to clean it up with cloth,if its still not working,try to use other memory,then you have to clean it up also the cpu,coz it might have dust inside it can cause hang up..!!thanks..
Aug 18, 2011 | Dell Computers & Internet
I'm hearing some unwanted sound after I turned-on my acer netbook. Also the monitor is keeping on blinking when the sound comes out. It's like a sound of a small blower or a small dynamo. I'm afraid that...
Hello
OK, now, the only components in your computer which actually rotates which can explain the the sound you are hearing is either the CPU fan or the CD/DVD rom or the Hard Drive.
You can test if it is the CD/DVD rom by opening your CD/DVD rom while starting the computer up. If the sound persists, it is most probably your CPU fan.
The reason for your CPU fan to rotate at high speeds is most likely the result of the CPU itself not getting the sufficient cooling, hence the fan needs to rotate faster.
I would suggest that you have a look into the matter if it is your CPU fan, because this might cause your CPU to become faulty when it overheats. You can open up the unit and use some compressed air to get rid of all the unwanted dust particles on the CPU heat sink and fan.
Fell free to let me know if you need any further assistance.
Kind regards
Andrea
Nov 22, 2010 | Acer Aspire One PC Notebook
When I start my CPU, I hear a sound that shows me that the equipment is on (that it's working), but the screen stays completely black, no light, no image on it. It happened all of a sudden. I switched it...
that iis not clear from wheryou heare sound.. monitor or cpu. if u hear sound from cpu your cpu fan is not working properly.. that cause processar may be damage,2/ some time damage ram shown same type symtom.change it to find outfault.
Jun 15, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I loss my sound driver .. i want it fast any my pc is "intelR) pentium(R) 4 CPU 2.40GHz 2.39 GHz,496MB of RAM " so any body can give me it.
Sound driver is a thing that is related to motherboard not cpu if you post cpu name no one can help you.
just post the motherboard name and you can get your drivers.
Apr 22, 2009 | Computers & Internet
Beep sound when swith on
good day,
a beep from your cpu system means that there is an error. and since there is a "cpu overheat" error, it could mean that your cpu cooling system (or its fan) is not working.
the shutdown is a defense mechanism of your cpu in order for your cpu not to self distract.
have the cooling system replaced as soon as possible to avoid further damage.
i hope this will help
Oct 13, 2008 | Intel D845GVSR Motherboard
Want to know applications of DMA in real time
Good Morning
IT it a little "brige" to some sound aplications or routing signal to Printers or Sound Cards, but not for Network. Not good sometimes for Sound Cards, but you can play sometimes with settings and see what happend, you always can go back the DMA at previuos state, or simple, disable.
Carl
Nov 17, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
ABIT-BL7 make sound
For reference, specifically, this would be indicative of an alarm on the motherboard. The only typical alarm of this nature would be an overtemperature alarm, either for chassis or (more typically) CPU temperature. In this case, it sounds like the CPU fan was failing, causing the CPU to overheat; once the threshhold temperature was reached (BIOS configurable), the alarm sounded. Remember, boys and girls, if your computer is making a sound like an ambulance, there's probably something bad going on.
Aug 15, 2007 | Abit BL7-RAID Motherboard
Intel D865GBF Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
