Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
How does belt tentioner go on
How does the belt tentioner go on to hold the belt in place.do you have a diagram ???
  • 5,911 Answers
Go to repairclinic,com and click on the "Repair Help" link. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. There is an extensive list of dryer belt diagram illustrations to choose from. Scroll down until you find Maytag. If you have any questions, please let me know. I hope this helps you.
Posted on Feb 03, 2010
What are the serpentine. Scamadics on a triton v10
Many manufacturers place a routing sticker somewhere in the engine compartment - did you look around at all for one?
Jan 07, 2015 | 2000 Ford F250 Super Duty Crew Cabs
How do change a serpentine belt in my 1994 Grand Jeep Cherokee?
first if old belt is still on jeep draw a diagram of how belt is routed first even i get confused motor needs to be cool release tention on belt some have spring loaded tentioners some you have to losen the center bolt on tintioner pully and turn ajusting bolt to losen belt install new belt tention propley
Jan 21, 2013 | 1994 Jeep Grand Cherokee
How do i remove the fan to replace the serpentine belt
do not remove the fan. you have a automatic belt tensioner. look for small pulley to passenger side of fan. pulley will be attached tp leaver which is the tentioner. on the leaver in a 3/8 dive hole in it so you can attach a ratchet or braker bar in . once you in mount ratchet push or pull on ratchet to release tention hold back on tentioner and take belt off pay close attention to how the belt is routed.
Jul 13, 2012 | Cars & Trucks
Need to know where the tentioner pully goes to put the belt back on
Difficlut to specify as you did not indicate the make or model of your dryer, but usually the tensioner goes into slots on the machine base, and the belt holds the tensioner off of the interrupt/safety switch...
Feb 25, 2011 | Dryers
Replace a serpintine belt on a lincoln mark 7 1997
If your asking how. It's simple make a diagram of the belt routing (there might be a diagram on the frame under the hood). Ther is a tentioner pully that holds the belt tight. Get a ratchet with the proper socket fit it on the nut n the center of the tentioner and you can pull the tendioner pully as to le6t the belt have slack. then carefully take it off of the pully . youll have to twist and wiggle it to come out from behind the fan then install the new one in reverse
Sep 09, 2010 | 1997 Lincoln Mark VIII
How to install cerpetine belt
Usually on the radiator support under the hood there is a diagram on how to "route" the belt. You need to release the tention and hold it while you get the belt off either pully and then when you put it back on. Some places like Parts America, Pep Boys, etc. will change it for you right there if you buy the belt from them. A garage shouldn't charge you much to change it either, it only takes about 10 minutes.
May 30, 2010 | 1998 GMC Suburban
Need help resetting tensioner 4 timing belt
Put the tention in a vise . slowley compress pin then stick a small nail or drill bit through hole, This will hold it in place while you install tentioner, Then simply remove nail
Mar 13, 2010 | 2004 Toyota 4Runner
I cannot get the serpintine belt back on the pully after changing the water pump is there an adjusting screw abd where would I find it 1996 pontiac sunfire
there should be a tention pully that is spring loaded and you will need a socket to fit the bolt in the center. then turn clock wise and hold to release tention and set belt in place then slowly release the pully
Jan 16, 2010 | 1996 Pontiac Sunfire
How to replace a broken fan belt
This is a surpentine belt. You have one belt that runs lots of things. Under your hood you should have a diagram for the belt. If not you can go to the ford dealer and get a diagram. You will ned a ratchet to release the tention on the tention arm. Try to put pressure one way and if you can't move it the go the other way. When you can move the arm put the new belt on and move the arm to fit the belt on. Thats it. Look on Youtube for a video on how to do it. Good luck!
Nov 06, 2009 | 1994 Ford Taurus
How to place belt on dryer drum
Take the hanging part of the bottom of the belt and place a finger through the bottom and pull it toward the belt tentioner , you may have to pull the tentioner with your other hand until you reach the motor shaft , loop the part of the belt your holding with your finger around the motor shaft , that should be it. Hold the drum straight and roll it clockwise a full turn to ensure it is correct.
Let me know how this goes.
Phil
Apr 10, 2009 | Dryers
Open Questions:
See all Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Questions
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
509 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
