Question about Samsung CLX-2160N All-In-One Printer
CLX-2160 hangs in "Warming up" after firmware upgrade. It is not detected via USB nor LAN. Switch on/off doesn't help.
ronaldsuboc
  • 449 Answers
SOURCE: Samsung CLX-2160, keep getting faded
hi!!!
may the drum try to replaced the drum!!!
Posted on Oct 22, 2008
SOURCE: Samsung clx-2160 says waste tank is full. What
If you open the front of the printer then you will find a waste tank in the left side - its gray. Take it out and empty it, and put the tank back in place.
This works for Samsung CLX-2160
Posted on Apr 01, 2010
picipolman
  • 9 Answers
SOURCE: I need to reset the transfer belt counter
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Posted on Jul 28, 2010
picipolman
  • 9 Answers
SOURCE: replacement transfer belt on my Samsung CLX-2160 not recognised?
  • 903 Answers
SOURCE: transfer belt error samsung CLX-2160 help
The first thing to try is to turn the printer off, unplug it from the wall, then plug it back in and turn it on. If the error message goes away, you can resume normal operation. If the error message still appears, you'll have to call your service technician.
Posted on Nov 27, 2010
Printer toner black reset firmware for samsung clx-2160/see
It seems that there are no Samsung CLX-2160 firmware reset/fix, if i'll find something i'll keep you posted
Jan 27, 2012 | Samsung Office Equipment & Supplies
Samsung clx-2160 printer is showing transfer belt error. how do i sort this
transfer belt (and other consumables) will reset follow this procedure:
1. go in diagnose mode:
menu - # - 1934 - menu
2. in tech mode -consumables counter - transfer belt -reset
3. after 20 sec. power off and power on
When transfer belt count 60.000 image need to reset.
good lock!
May 28, 2011 | Samsung CLX-2160N All-In-One Printer
I have a Samsung CLX-2160 print. It says "transfer
Try this steps it might help,
1. detach the paper tray and push it back correctly.
2. open the front door and remove toner cartridges, on left inner side u may see a light sensor which detects the toner cartridges.. simply clean this section by a small cotton bud. and in the left side of toner unit there is a sensor door, behind that door there is also a light sensor bulb, which needs to be cleaned by a cotton bud.
Please rate this solution if found useful.
Thanks
Jan 17, 2011 | Samsung CLX-2160N All-In-One Printer
I need to downgrade to previous firmware for Samsung CLX printer. (clx-3170 0r clx-3175)
Unfortunately, once you install a firmware upgrade it is permanent. Driver updates can be reversed but not firmware. That is why you should always have a definite reason for upgrading the firmware.
Jan 06, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I can't connect to Edmini via LAN nor USB. LAN computer doesn't detect then I tried to check edmini from browser then I get this message /www/cgi-bin/public/sharelist: line 246: cannot create temp file...
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jul 29, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hp designjet Z3100 photo plotter 79.04 error
It Seems It Could Be a issue with Formatter
but still We Can Do A Emergency Firmware Upgrade ,Mail Me For Detailed Steps
Apr 06, 2009 | HP Designjet Z3100 InkJet Photo Printer
Samsung CLX-2160N All-In-One Printer Logo
389 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
