While trying to set up with my WyFlyer WDB20B it lost or changed the IP address and Ican not get it to communicate with my computer. How do I reset the IP address or determine what the new one is?
  • 63 Answers
Shut down your computer, unplug the hub for about 1 minute. plug it back in then turn on your computer. if it still can't find it, do the same thing, but after unplugging your hub, there is a reset switch in the back, very tiny hole. press for 5 second to restore factory settings and then plug it back in and restart your computer.
Posted on Feb 03, 2010
Testimonial: "I tried the little hole, it did no good. Next I unplugged it, held down the "dial/unhook" button, plugged it in and held it for 20 seconds. It works."
Reset a printer that will not connect wirelessly
Usually disconnecting the router and printer works. I would power the router up first than the printer.
The solution that works best for me is to reserve at the router a block of Ip addresses that it can not assigned by the router.. Than on the printer I manually set the Ip address(static) one of the blocked Ip addresses. I than use the manually set Ip address of the printer in locating the access with my PC. The prohibits the router from changing the Ip address resulting in the printer getting lost in the network from the computer when I want to print.
Hope this helps.
Sep 28, 2016 | Canon Office Equipment & Supplies
RCA DCM425 modem ethernet connection won't work
The setting for the Computer 1, use the network connection wizard to automatically configure the modem to work as a server station. Next, set the IP number manually and the DNS at automatic or is given by your ISP. Now the Computer 2 (workstation) should be connected to a Hub/Switch. The same, go to network connection wizard and select the appropriate connection setting, there are view samples for the connection types so explore them. After the setup, try loading your internet browser.... When done, it should work fine. Keep me posted for any problems.
Nov 26, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Hpow u change ip adres
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Cannot log on to dwl2000ap
If the SSID changed to the default then you know that the router reset to the default settings and you should set your computer to automatically get its IP address via DHCP. I always set up my routers through a Wired connection first, just to setup the router and then go with the wireless. The default for the router should be 192.168.0.1 and subnet 255.255.255.0 . If the computer is set with a static IP address, change it to obtain an IP address automatically or the network card will not bother even looking for an address.
Aug 17, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
WR850 Install Problem on new VAIO Laptop with VIsta
try to change your OS! frfom VISTA to XP. because sometimes the problem is in not the router rather the problem is, conflict bet. IPv6 and IPv4.
Apr 01, 2008 | Arris WR850G Router (DHWR850G)
Set up the DWL-G710
Make sure you are using the right range of IP addresses, for instance, if your device has a default address of 192.168.0.1, then your computer must have a manually input address of something like 192.168.0.2, otherwise the devices will not communicate. You can change the address on your computer be going into your network connections folder, right clicking on your LAN folder, selecting properties, then right click on TCP/IP protocal on the protocal list, and also select properties. Here, you must uncheck the "Automatically Obtain IP Address" option and input the address shown above. The next two boxes will be 255.255.255.0 and for Default Gateway enter your devices IP address. Don't worry about the DNS address for now. Press ok to save the settings. You may have to restart your computer when you are finished. I hope this information helps you. Good luck!
Nov 05, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
Cannot reset 2wire 1000hw IP
The fact that you receive an IP starting with 209.154.. could also coming from the fact that the DHCP server inside your 2wire has a problem or that your 2wire changed some setting.
I would like you to open internet explorer and put the following address:
http://gateway.2wire.net/management
If the above address doesn't work, press Start, Run, type cmd and press enter.
At the prompt type    ipconfig /all  and confirm that the Default Gateway has an IP address similar to 172.16.0.1 or something else; if there is no value means that there is no communication with your router and we have to verify the hardware.
If there is an IP address on your Default Gateway, try to ping it by typing  ping xx.xx.xx.xx   change the xx with your Default Gateway IP address.
If you are not getting any reply means that the router doesn't communicate again, if you see some reply means that you can probably access to your router by opening internet explorer and entering the following http://xx.xx.xx.xx  where xx is your Default Gateway address again.
Please let me know up to where you can get some result and then we will continue from there.
Oct 30, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
488 people viewed this question
David Payne
David Payne
