Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Our tv just shut off w/ red light blinking on lamp..we tried to turn unit on & off but it doesn't work?
Chu3505 is right. I just replaced mine for the same reason and it works great. Lucky though it was still under warranty. They just sent out a new one and I did the work. Cake.
Search the internet to find a good price. I've seen them for $150.00...
Posted on Feb 18, 2010
  • Sony Master
  • 8,457 Answers
Lamp blinking indicate lamp dead, must change lamp it dead.
Posted on Feb 03, 2010
Mitshubishi WD-62327 TV will not turn on and no sound. TV made a interference sound and shut off. Tried to turn it in the morning still nothing. Replaced lamp/bulb still nothing. Red light is on (not...
If you have a voltage meter there are some things you can check.
Unplug the unit and remove the back cover of the set. Then Plug the unit back in.
You will need to tape down the lamp safety switch in order to do these tests.
Here are all the failures that would give you a lamp error and what to check.
Cause 1. Unit powers on and works properly for a while then shuts off with a red lamp led(lamp error). Suspect bad lamp and replace.
Cause 2. Unit does not power up correctly and you have red lamp led(lamp error). Check the lamp enable line at connector J14 on the back of the light engine. If pin 6 does not switch to 5 volts after turn on, but your 12 and 5 volt supplies are good, then suspect a defective light engine.
Cuse 3. At power on the lamp turns on and off 3 times and then the unit shuts down with a red lamp led(lamp error). You have a defective light engine.
Cause 4. Unit does not turn on correctly and you have a red lamp led(lamp error). Check for 12 volts at connector J9 pin 4 on the light engine. If voltage is missing check for an open fuse F9A09 on the power supply board. If it is open, then you need to replace the fuse and you still have a defective light engine.
Cause 5. Lamp enable line at connector J14 pin 6 on the light engine does go to 5 volts at turn on, but does not drop back to 0 volts after 5 seconds, but your 12 and 5 volts supplies are good then you have a defective light engine.
Cuase 6. Check for 5 volts at connector J9 pins 1 and 2 on the light engine. If low or missing check Capacitors C9A37 and C9A38. Values are 3300MF/10V. Replace capacitors if defective.
This is all I have and I wish you luck.
Mar 20, 2013 | Mitsubishi WD-62327 62" Rear Projection...
Samsung dlp tv wont turn on, blinks lamp light green and temp light red
These blinks of LEDs are fault indications. If you wish to get more details about these blinking codes, check this link. The details are there. It is very difficult to include all those details in tables here by this window.
Feb 03, 2013 | Samsung HLN467W 46" Rear Projection HDTV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
TV turns off after two minutes. Power light blinks for a few minutes then TV comes back on. Turning the power off after the set shuts itself off will cause the power light to blink five times for a minute...
5 blink indicates - AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
Jan 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
356 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
