Driver is not supporting for Windows Vista OS.
Scanner Ricoh 2022 driver is not supporting for Windows Vista OS.
    President:
  • 2,022 Answers
Kindly download the driver from this link,
http://support.ricoh.com/bb/html/dr_ut_e/re/model/x2022_27/x2022_27en.htm#Microsoft%20Windows%20Vista
Have a nice day and do not forget to rate please...!
Posted on Feb 03, 2010
I Want Ricoh Aficio SP1000SF dirver for Windows 8 (64 bit)
Download the software here...
http://support.ricoh.com/bb/pub_e/dr_ut_e/0001246/0001246934/V204j/z60275L12.exe
After extracting the files and getting the error message that you OS is not supported, browse to the Companion Pro LL V2_0_4 folder and open the Companion folder. Double click setup, and only install the Printer and scanner drivers when prompted. The default location that the software is saved to is listed below...
C:\Users\"your user name"\AppData\Local\Temp\Companion Pro LL V2_0_4\Companion
Jul 28, 2014 | Ricoh Aficio SP1000SF Multifunction...
My cable that came with my ricoh is01 does not seem to be compatible with with my scanner and neither can I plug it into the pc.
The Ricoh IS01 uses a SCSI 2 (50 pin) interface. It should look like the one here: http://www.amazon.com/Cables-Go-03564-SCSI-2-Cable/dp/B000051312 . There are SCSI to USB converters but I'm not sure if you need a specific version. (Scanners require bidirectional communication with the computer so there were few interfaces that required a special connection.)
Depending on your computer's OS, there may be other issues. (Some may not be compatible with Windows Vista or Win7, for example.) Drivers for some OS versions are available here: http://www.ricoh-usa.com/downloads/downloads.aspx . Search for the IS01 (no other information is needed)
I hope this helps.
Jan 01, 2011 | Ricoh Aficio IS01 Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Ricoh MP2000 with scanner /Printer on Linux
This is older machine model and drivers are made only for UNIX and SAP/R3 you can try and test does will work with this drivers because and this are open source.Here you are link and select " Choose other OS " http://support.ricoh.com/bb/html/dr_ut_e/re1/model/mp15/mp15.htm
Feb 08, 2010 | Ricoh Office Equipment & Supplies
UMAX ASTRA 4100/4600 DRIVER FOR VISTA / WINDOWS 7
I don't know about Windows 7, but I'm using my Astra 4600 on Windows Vista.
Umax said on its website that the Astra series of scanners are not supported for Windows Vista/7. I suppose this is to get us to buy new scanners...
I searched all around the internet for my driver, but couldn't get one. Finally I tried one more time using the CD that came with my scanner. Of course it doesn't work if you run Setup.exe from the CD --- it will just tell you that the OS is not supported. So I went to Device Manager and deleted the scanner under the "unknown USB device" section, and unplugged the scanner.
When I replugged the scanner, I let Vista install the driver automatically. Of course it couldn't, as Microsoft doesn't support it either. Then the install wizard asked me to put in the CD that came with the scanner. And that did the job! Vista was able to ignore the fact that the driver wasn't written specifically for Vista, and the scanner is working!
I hope you have the same luck with yours.
Happy new year.
Feb 04, 2010 | Office Equipment & Supplies
kindly download the driver from this location,
if you face any problem let me know.
Feb 03, 2010 | Office Equipment & Supplies
Umax astra2500 drivers for windows7 home
intstall scanner driver umax astra 2500 supports for windows 07
Dec 23, 2009 | Umax Astra 2400SLT Flatbed Scanner
Umax Scanner Astra 4100 Drivers for Window Vista
required umax astra 4100 scanner driver for vista/win2003 server
Jul 27, 2008 | Microsoft Windows Vista Ultimate Edition
Scanner installation in vista OS
this is not support you have to go the web site and download the software and driver of the scanner o/s vista 32/64 any one
Jun 01, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
