Question about Compaq Computers & Internet
My compaq laptop is not getting started. When i am conecting the charger the light is not display. May i know what will be the problem
  • Compaq Master
  • 32,281 Answers
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Feb 03, 2010
  • geotester Aug 10, 2011
    Solve the problem of no power supply for Compaq Presario CQ71
    I was trouble by this problem twice: The Compaq Presaio HP AC adaptor cannot give power to the Notebook. The small light beside the socket is off.
    For the first time I broke the AC adapt, it seemed no burn happened. I got a new AC adapter from my IT support and it worked.
    For this second it is almost one year later. My IT support is on holiday. I tried many ways to fix the problem: take the battery away, short cut everthing (not battery) and thinking it will reset something (since the AC adaptor is an intelligent one. It shows 18.5V output, but when measure it, it gives a reading of 1 or 2 V in voltage output).
    All the measures did not work.
    Then I got some enlightment: 1) take off the battery and adaptor from the notebook, hold the notebook power button for 1 minute. 2) put on battery and connect AC adaptor, hold the notebook button for 1 minute again. You will see the blinking of the charger indicator LED on the from edge of the notebook. Then you will see the light beside the socket is ON! 3) release the power button and let the notebook charged for a while. Finally you can boot your Note book again.
    (give me a thank if it works for you geotester@hotmail.com)
Screen display is blank
one of two things the screen needs replaced or the hard drive or graphics card are goosed
Nov 10, 2013 | Lifetime HP Compaq Presario CQ45 Series...
My notebook does not come notebook on any more why?
It maybe Athlon X2 shorted out. Replace the cpu so that it will not shut down the charger.
Jan 30, 2012 | HP Compaq Presario CQ50-210US Notebook
HP Pavilion dv6-3007tu
what exactly is your problem? will it not start?
Jul 25, 2011 | HP Pavilion dv6-1122us Notebook
My compaq presario v3500 wont turn on again. i was using it, watching movie then it suddenly shutdown. my battery is fully charge and the charger was connected. so i try to turn it on and it wont start....
Remove the Battery and press power on for 1-2 minutes with out AC power .
Please turn on the laptop with only AC POWER (without battery ). Check it. it may turn on your laptop.
If display ok, then insert battery and use it...
Jun 18, 2011 | HP Compaq Presario 2200 Notebook
My compaq laptop turned on after few seconds turned off it is (no display observed). laptop starts or its power light starts after pressing F10 button but no display on screen ocurs
Hi Bonde Ramipr,
It is possible that you have a faulty display, can you connect your notebook to an external monitor?
you will need a Monitor and a VGA cable (the same cable you use to connect a normal PC to a monitor).
after you conect the notebood to the monitor start your notebook. you should be able to see the boot process on the monitor, if not you may have to tell your notebook to use the external monitor. you can do this by pressing the "fn" key on your notebooks keyboard and at the same time pressing the key that cycles the display output. I will try to get a picture for you.
Oct 21, 2010 | Compaq Presario C700T Notebook
How i can check the dell nps-460bb power supply working or not?
If there is a light on it and its on, its a start, if you have a volt meter u can get a reading from the conection that goes into computer. check the pins inside this conection with a pen see if they are loose, another way is to place the black box againts ur ear firmly listen carefully for a hum, if its hummmming then its working, if the charger aint pwoering the laptop check the conection that goes into laptop for any loose parts, another problem can be the laptops conection its self , give it a sligh push to one side or the other to see if it lights up the laptop, or try it in another laptop that uses the same conection.
hope this helps in some way.
Dec 02, 2009 | Cars & Trucks
I have a compac lap top and when i plug in the wall charger nothing happens it wont charge
check to see if you can hear a hum from the charger it self , push the box hard againts ear if its humbing charger is ok, if you cant hear anything from it check fuse to plug. if this is ok then charger is broken.
If charger is ok check the conection into the laptop if it feels loose and when u move it slightly it goes on and off then possible conection to laptop prob.
If this conection is ok and the charger is humbing and working, could be a possible internal switch gone in the laptop that decides to charge and not charge when battery is full. These are always failling on laptops but hopfully its not this.
If you find the charger is broken search ebay for a new or secound hand one, aint to expensive. hope this helps
Nov 28, 2009 | Compaq Computers & Internet
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
Power button has light turning on and off with no other signals !!
try,,holding the delete key down as it is starting up,,,will the computer boot into Bios?
do you see any information on the screen when you start the computer at all?
Aug 19, 2008 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
499 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
