My mfc-665cw printer quit printing yellow. i have switched cartridges, run the cleaning mode many times, no improvement. i hate to dump the excellent printer or pay big bucks to have it checked.
  • ljenseward Feb 03, 2010
    This is a one-size fits all response. There is no copper circuitry strip on this model cartridge or printer, so the hints are of no value whatsoever.
    President:
  • 2,022 Answers
Remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Have a nice day and do not forget to rate please...!
Posted on Feb 03, 2010
Testimonial: "tip was of no value as the response did not fit the printer at all."
  • mukhtar21 shaikh
    mukhtar21 shaikh Feb 04, 2010
    i m very sorry for that my solution was not help you out can you try one more thing just re install the printer driver and try.
    best of luck.
MFC 240C will not print yellow despite new cartridge
check if plastic cover on ink cartridge . may need a lot of cleaning of print heads may need to get cleaning alcohol and a cloth and clean print head physically
Dec 24, 2014 | Brother Multi-Function Center MFC-240C...
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
Brother MFC-240C PRINTER yellow will not print
Try cleaning the heads - either with the printers software / drivers, or manually with q-tip and alcohol.
Mar 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
Want to set brother 665CW to print black and white
It can be done, but all ink cartridge need to be in printer.The printer need all cartridges to initialized.When you start printing something click on Properties then find Advanced.There is a option Colour/Greyscale.Check on greyscale and it's done.
Oct 28, 2009 | Brother MFC-665CW All-In-One InkJet...
"Ink level Yellow Low"
where the cartridge sits in the machine, you will see a sensor that reads the cartridge ink level, either the sensor is dirty or needs to replaced, and did you try an new Brother cartridge?
Jun 06, 2009 | Brother MFC-665CW All-In-One InkJet...
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
Won't print won't run clean routine
Did you try this
Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved,
Apr 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Yellow will not print
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 22, 2008 | Brother Multi-Function Center MFC-665CW...
Ink cartridges....
Which cart arent recognized? The yellow one or the cyan(blue) one or both?
Anyway:
Unplug machine from power. Wait three minutes. In this time take all carts out and close cover. reconnect machine to power. Machine demands carts. Open cover. Reinsert carts. Make sure that the support clip of the cart.holder is secured above the cart cover.
If you still have probs with one cart. the led contact on the circuit board is defectiv. You need a new cart holder then, which can be ordered as a spare part from a service partner near your home (see brother homepage).
Nov 13, 2007 | Brother MFC-3240C All-In-One InkJet...
49 people viewed this question
jasbo
jasbo
