Question about Compaq Presario 5000 PC Desktop
Monitor goes black
When i coonect the monitor to the back of my computer the monitor turns black when i unplud it it says testing and has colors i tried a different monitor and it does the same thing it has testing on it when I plug it to pc it goes black.
  • 115 Answers
This is the problem of motherboard or RAM.
First you remove your RAM from motherboard clean it and also clean the RAM slot then again install it.
Your problem should be resolve.
Regards
Ashly
Posted on Feb 03, 2010
  • Compaq Master
  • 32,281 Answers
It appears the video card is faulty. Try a different video card.
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Hi, I have a Dell 23 in monitor. Everything was working fine but one day we turned it on and it's completely white. The whole screen is just white. Is it there a simple solution?
please remove the vga cable from the back of the monitor, make sure that you don't remove the power cable from the back of your monitor.
If you see the power on self test or any other pattern of colors in the screen, if the screen display remains white or goes black it would mean that the monitor has gone bad.
Hope it helps.
Thanks and Regards
Anand Sachan
Oct 25, 2010 | Computers & Internet
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Color problem
IT is 18 years OLD so has CCFL back lamps that all turn yellow.
is that it? if the OSD is yellow the (white looks yellow) that means the CCFL black lamp tubes are Shot.
i cant see what you see, no photos posted.
ok the monitor has and OSD, on screen display
i see you found that. but then fail to say what you saw there.
"you could see the background on the text as white. "
what does that mean,?
no matter what that is a bad Monitor.
the OSD works with no computer at all, so if the OSD fails
OSD brain, inside, then the monitor is bad.
all monitors worked previously so is not key to why its failing now.
only the tests now, matter. today/
my post above is for any monitor that fails the OSD tests
no PC turned off. or connected to any PC that works
the PC resolution must never exceed
1024 × 768 at 75 Hz Refresh Rate
on this old old dog. or the screen goes back with error
OUT OF RANGE.
Aug 27, 2017 | Compaq TFT5010 (Opal) 15.1" LCD Monitor
My screen has gone black
try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Jul 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Compaq Presario 5000 PC Desktop Logo
153 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
