Question about Hotpoint Aquarius WF000 Front Load Washer
Wont do a wash cycle
Prewash light comes on almost immediatley clothes are not very wet help
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
If the pre wash led is flashing it indicates a h20 error (time out filling) some common causes are fill hose twisted trapped or kinked tap not turnd on the waste hose is connected incorectly and is causing the applionce to syphone if your waste pipe gose into a down pipe ensure it is in no more than 4 inches maximum and if it is connected to the u bend undr the sink you need to make sure the pipe gose above 60cm high at some point.
Posted on Feb 22, 2008
What is a pre wash? which detergent to be used in the pre wash compartment?
A prewash is exactly that a wash that takes plaxce before the main wash cycle for heavily soiled clothes, you can use the same detergent as you do for main wash. I do not think that I have ever used prewash.Hope this helps
Jan 06, 2016 | Kenmore Elite 45986 Front Load Washer
As soon as I put coolant in the reservoir tank it drains out but cant see where its going and the ground is wet WHAT COULD BE THE PROBLEM?
Sounds like the tank has a leak, remove the tank and inspect, you should be able to see if its wet underneath.
Mar 08, 2015 | Saturn 2001 SL1 Base
Today I did a load of washing and it worked fine. I then started a second one and when I looked at the machine, the timer showed the number 1 and the light was on prewash. the washing had not been...
hi I think the door lock is faulty it always shows 1 min until the door lock is unlocked. also will not start until it is locked. e40 is the error for starting the machine with door open but if if faulty will revert to the last minute. include product no and model if further info needed you can find this on a label in the door area.
Nov 08, 2010 | AEG Washing Machines
Built in thermador, 9 years old. when dishes are d...
Eggs cause wet dog smell in my dishwasher. Prewash anything that has come in contact with either raw or cooked eggs before putting it in the dishwasher. I haven't had the smell since I figured this out.
May 17, 2010 | Dishwashers
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Flashing lights
Not heating, check element and thermal fuse/thermostate. Regards Advisor
May 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Prewash always flashing
yes i had a similar problem the prewash light kept coming on mid wash cycle and eventually stopped taking in the water just bypassing it straight to outlet without filling machine. i found if you remove the pump at the rear of machine and disconnect hoses there was a build of lets say deposits leading to a sensor through a opaque plastic connector to the top of machine . after cleaning the hoses thoroughly and removing all the crud machine worked as it should do, hope this helps
Jun 06, 2006 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
115 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
