Question about Dell Inspiron 6000 Notebook
Have to restart to get sound working and then it only works for half hour before i have to restart again.
  • jmomenit Feb 11, 2010
    the above solution worked for a while but now i must restart to get sound working again
    Sniper:
  • 68 Answers
Go to the device manager and then remove the insalled sound driver after that restart the computer it should pick the drivers automatically if not the go to the website and enter your service tag then you will be able to download all the latest drivers for your system
http://supportapj.dell.com/support/index.aspx?c=in&l=en&s=dhs
Posted on Feb 03, 2010
Testimonial: "thankyou for responding. i thought the problem was fixed after uninstalling the driver but i am having the same problem again"
Danny DPA120B1WB portable Air conditioner 12,000 Btu will not produce cool air. The fan will start but no cool air. I tried to reset, restart, and clean filters.
This may sound foolish but it works turn the unplugged air conditioner upside down and leave it that way for about hour and a half , then turn it back over after the hour and a half let sit for half hour plug it in and it should blow cold air , by turning it upside down it allows the oil in compresser to flow
Jul 23, 2016 | Danby Heating & Cooling
Why could I sign in less than a half hour ago and now I cannot?
Sure you did not lose your internet connection?
Perhaps you should restart the computer or the tablet you are working with. Then start the browser again and look it that works.
Jan 16, 2015 | Computers & Internet
RED LIGHT COMES ON AND ALARM SOUNDS
Check fluids and filters, make sure there is no restriction on tubing, air intake. some times take out the filters etc. then reinstalling them will help. Also unplug for a while then plug it back in and see where that takes you.
Apr 22, 2014 | AirSep FreeStyle Portable Oxygen...
My dryer starts to work for about 5 minutes and then stops when i try to restart it ,it makes a buzzing sound and wont start
Sorry I am no expert here but it have you checked your filter? It may just need cleaned.
Alternatively it could be an issue with the fan. Over heating could be causing the unit to switch itself off if the fan is blocked or damaged.
Good luck
Nov 13, 2013 | Dryers
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
My dryer starts the first time with no problem, but after about an hour it starts to make a kind of buzzing sound. If I don't shut it off at this point it shuts itself off after another minute or two....
You are absolutely correct that the motor is the problem and needs to be replaced. The motor is overheating and its thermal overload protector trips off causing the dryer to shut down. Thermal overload protector resets and allows the motor to run again only when it has cooled down. It is the reason why the dryer is not turning on immediately after it shuts off. Replacing the motor will definitely solve the problem.
Aug 11, 2010 | Maytag Dryers
1991 Dodge Dynasty LE car will suddenly die while driving. If I pull off the road, turn the ignition off and restart it- will start but when I put it back in gear the engine stalls again. After five or ten...
Sounds like you are having a fuel problem with the fuel filter. If you have not had your car serviced in quite awhile i would do so. At least change the fuel filter and check the air filter as well. Hope thias will help you.
May 26, 2010 | 1991 Dodge Dynasty
F150 ignition (won't Start)
If it turns over but just won't fire and the timing sounds fine when it does run you might consider your ignition switch.  Does it sound like it wants to fire but only just when you let go of the key?
Aug 06, 2008 | 1985 Ford F150
Dell Inspiron 6000 Notebook Logo
681 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
