Question about Kenmore Elite HE4 Electric Dryer
How do you turn off the signal buzzer? - Kenmore Elite HE4 Electric Dryer
Electric dryer won't stop buzzing
Posted on Feb 03, 2010
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
Is this part I have related to my turn signal switch is on my 1976 cutlass supreme
I don't recognise it but it could be a clicker or a warning buzzer. Lots of drivers like to hear the turn signal clicking when it is switched on but it wasn't always convenient to design them that way so manufacturers sometimes provided a clicker to provide the required noise.
You could try connecting it to 12 volts via a small fuse to see or hear what happens.
Feb 25, 2015 | Cars & Trucks
Where is buzzer switch located on model crer5700as1
Good Afternoon Friend,
I understand you want to know where the buzzer switch is located on your Frigidaire dryer, model# CRER5700AS1. If your particular model dryer is equipped to turn off the buzzer, the switch will be located between the temperature knob and the start button, and named "Cycle Signal". If your dryer is not equipped with this feature, then there will not be an extra knob. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Dryers
Want to disable buzzer
Hello Craig McDaniel - The buzzer signal will sound when the cycle ends and briefly every 5 minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Feb 15, 2013 | Frigidaire FEQ1442ES Electric Dryer
2002 Cabrio... Where can I get a relay board?
Some manufactuers use a buzzer sound when you leave the keys in the ignition and car shut off. Some use a buzzer for a seatbelt that is not fastened when it detects a passenger.
The use of the turn signal or Hazard could break the circuit and silence the buzzer.
Jun 04, 2012 | 2002 Volkswagen Cabrio
I have an older kenmore dryer. i want to disconnect the signal buzzer. can i do that?
Since there is no switch to turn off the signal on the dryer, you would need to unplug the laundry centerand disconnect one or both wires that are connected to the dryer buzzer. The buzzer is shown as Key 38 in the first image below. The procedure for accessing the buzzer in this type of laundry center is provided in the second image below. You would need to insulate any wires disconnected from the buzzer with electrical tape or a wire nut to prevent them from shorting to the dryer cabinet.You should only conduct this procedure if you are completely confident in your technical ability to safely complete the process. Be sure to unplug the laundry center before accessing internal components. Internal metal edges can be sharp. Protective gloves are recommended.
Apr 01, 2010 | Dryers
Can the end of the cycle the buzzer be turned off?
On the display panel under the start button is a signal indicator. If you push the button to the left of the indicator you should be able to reduce the volume and even turn it off. The button on the right of the signal indicator will bring the volume back up.
Jan 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
1998 Dodge Ram 1500 4WD blowing fuse when turning left signal on
left side u got a short
u can wire up a buzzer or light to plug into where the fuse goes that blows when u turn on ur left blinker the buzzer will sound or the light will come on ,while the buzzer is on take apart left signals
and check wiring by moving harness around ,when u find the short the buzzer will quit
Jan 21, 2009 | 1998 Dodge Ram 1500 4WD
Replace ignition tumbler
STEP BY STEP Please Remember to Rate Me Thank You RejakWilson
WARNING: On vehicles equipped with Airbags, disable airbag system prior to performing service procedures.
  1. Disconnect battery ground cable.
  2. Remove steering wheel as outlined under STEERING WHEEL procedure.
  3. Using a screwdriver, pry cover from housing.
  4. Using lock plate compressing No. J-23653 or equivalent, compress lock plate, and pry snap ring from groove on shaft, Fig. 5. Slowly release lock plate compressing tool, then remove tool and lock plate from shaft end.
  5. Slide canceling cam and upper bearing preload spring from end of shaft.
  6. Remove turn signal (multi-function) lever.
  7. Remove hazard warning knob retaining screw, button, spring and knob.
  8. Remove pivot arm.
  9. Wrap upper part of electrical connector with tape to prevent snagging of wires during switch removal.
  10. Remove switch retaining screws and pull switch up from column, guiding wire harness through column.
  11. Reverse procedure to install.
  1. Remove turn signal switch as outlined under TURN SIGNAL SWITCH.
  2. Remove buzzer switch and spring clip. On 1990-92 models, ignition key must be removed from lock to remove buzzer switch. On 1991-92 models, switch and spring clip are one assembly.
  3. Turn lock cylinder to Run position on 1989 models or Lock position on 1990-92 models, then remove lock cylinder retaining screw and the lock cylinder.
  4. To install, rotate lock cylinder to the stop while holding housing. Align cylinder key with keyway in housing, then push lock cylinder into housing until fully seated. Lock cylinder must be in Run position to install buzzer switch.
  5. Install lock cylinder retaining screw, then the buzzer switch, turn signal switch and steering wheel.
Aug 30, 2008 | 1989 Chevrolet Celebrity
Kenmore Elite HE4 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
