Question about Mitsubishi WD-62531 Projection Television
I have a mitsubishi wd-62530 that I have just put the lamp into and all it does is blink a green light on the front panel timer light. I have made sure my lamp is in right and the panel is closed but it still will bot turn on.
  • 111 Answers
Dm module has bad caps on it
Posted on Feb 03, 2010
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
My Mitsubishi tv model wd-62525 not on the light of timer is linking
If one light is blinking (lamp light?) remove and inspect lamp to make sure it is in correctly and not shattered. If the set has a recessed reset button on front (if set is unplugged and plugged back it should blink green for about 70 seconds and go out) you may have a issue there.
The model indicated here has a host of problems.
May 20, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
May 18, 2011 | Mitsubishi WD-60735 Projection Television
II HAVE A 65" MITSUBISHI TV MODLE WD-62530 JUST
move all other electronics away from the screen mine did it too
Nov 17, 2010 | Mitsubishi WD62527 62 in. LCD HDTV
Hi...I replace the lamp in my WD-62530 and is work fine until I turn off , try next day and the tv don't turn on, you can see the led green light in front the tv is on for about 10 sec and is off, remove...
U recheck all the connections u take out,when u change the projection lamp and put it all back in all the connections back in properly seated and tightly?Yes,than the board call the Ballast board have problems.This Ballast board job it help to ignite the projection lamp.Change the Ballast board,might solved this problems.
Oct 23, 2010 | Mitsubishi Televison & Video
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green timer light and fan turning on randomly, now no power at all
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
thanks
scott
Sep 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62531 Projection Television Logo
735 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
