Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Badger 5 Plus has vertical cracks in upper shell under caver at drain level can dis part be replaced ? were can i by this? Guarantee? thanks Gerald
My badger plus 5 is leaking from the bottom .is this repairable ?
Posted on Feb 15, 2010
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water is leaking from the base of the Badger 1. Appears to be coming out of the reset switch. Can i repair this?
There's only one repairable thing on a garbage dispostal, and that is where the pipe (drain) comes out. If it is leaking from there, it can be fixed. If not, it means the housing is cracked and you need a new one. PS don't turn the disposal on since it's leaking from the electrical connection!
Feb 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 leaking from middle of unit when motor is
Make sure the seal is tight where the unit attaches to the sink. It may appear that the unit is leaking elsewhere but is not. If you are sure it is leaking at the case, check for cracks or you could have a bad pump seal internally, in which case the unit should be replaced.
Jul 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 plus is leaking from the bottom, how do I fix it?
Sorry, but you fix it by replacing it. Once they leak, it means there is a crack in the housing. Easy to replace though. Feel free to email me for help....not sure if this leaves my email address, so here it is: BoRedSox1918@yahoo.com
Jul 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 plus garbage disposal (5-6 years) it humms
Yes, it sounds like you have a bad motor winding, not allowing the motor to actually work. It is time to replace. Hope this helps
Jul 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
If you need some part, take a look on amazon, here: Amazon com insinkerator badger 5 parts I bought replacement plate from there.
May 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Flywheel seal needs replacing if disposal leaks from bottom plate.
May 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
Dec 20, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
329 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
