Question about Belkin (F5D7231-4) Wireless Router
How do i put a password on my Belikn G Plus router.
  • 415 Answers
To secure your wireless router you should specify a WPA or WPA2 key (depending what your router supports).
To set it up follow the steps below:
Open an internet explorer and type 192.168.0.1 on the address bar above and press enter.
The router will probably ask for a username and password which if you haven't set it will probably be "admin" for the username and "admin" or a blank password.
Then go to wireless settings and choose wireless security. Choose WPA2 if it is available (avoid WEP as it not very secure). Then enter a passphrase that you will remember and save your settings.
When you try to connect from your laptop or other wireless device it will ask for the type (WEP,WPA, WPA2) and the passphrase that you entered. That's it!
Posted on Feb 03, 2010
How do i secure my belikn from outsiders using it
Enable wireless security on your router, so that other people will not be able to connect to your network.
To enable wireless security, access the setup page of the router through a web browser. Type 192.168.2.1 in the address bar.
By default, leave the password blank.
Once in the setup page, go to Wireless. Take note of your SSID. Then go to Security.
Select WEP or WPA, depending on the operating system and capabilities of your wireless computer. If in doubt, you may use WEP since it is the legacy wireless standard.
You can enter your WEP key manually by typing in the hex WEP key manually, or you can type a passphrase in the “PassPhrase” field and click “Generate” to create a WEP key from the passphrase.
Make sure to take note of the WEP key because you will be needing this for your wireless computer.
Click Apply Changes.
On your wireless computer, view the available wireless networks, select your SSID, then type the WEP key.
I hope this helps!
May 11, 2010 | Belkin (F5D9230-4) Wireless Router...
How do I change the channel on my Belikn N router?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How to put a password on Belkin GPlus Mimo 180170
you log on to the router usually an address like 192.222.222.2 etc should be in your manual and go into security then you will have an option to create a password. once this is done you will then need to re connect to your router and put the password in.go on to control panel then network connections.
Jan 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to put password to router
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I set up security for my router?I have a Belkin G plus mimo wireless router.
Login in into your router, then select security, you can turn it off, or change the name or password of your wireless router.
To log into your router you have to type in the browser:
192.168.1.1
put your user name ( default is admin or Admin only if you change it)
Put the password (usually it is password if not changed)
so when you log in, you will see the security tab, press it and change what you want. than save it .
Thanks for using Fixya
Oct 14, 2009 | Video Game Consoles & Games
My router which i have had for about 3 years has suddenly decided that it now needs a security key or password which iv never put on it how do i sort this or find out the password its a belkin g plus mimo
connect your pc to the router with a ethernet cable and open a web page. Type in the IP address of the router and this should bring up the routers configuration pages. In here you should be able to find out what the network key is and disable it if needed
Aug 18, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Please does anyone know the password for the belkin wireless g plus router version 1212uk please help
Which password do you ask? Router's password or wireless security password? For the router's password, by default it is admin in lower case. No username. If you are asking for the wireless security password, you need to login to the router's setup page and get the wireless password
Jun 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I forgot my network key? Belkin wireless G plus mimo router.
No problem if you remember your administrative password, just log into the router. Plug into the router with an ethernet cable and put 192.168.1.1 or whatever your router IP is (you can use ipconfig to find that: run, cmd, ipconfig -- it's the default gateway) into your web browser. If you don't remember that password either, then you're going to have to hit the reset switch and set it up again. Go to Belkin's site if you don't have your manual anymore:
http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=6131&scid=221
Mar 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I want to secure my wireless router
Put a password on it.Configure your router for WPA personal (WPA-PSK ) encryption
Jan 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7231-4) Wireless Router Logo
71 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
