Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
When remve battery the clock lost time and
When remove battery and reinstall it the clock lost time and camcorder say "set time"
  • distelecgx Feb 03, 2010
    Change the back up batteries located inside of the handle
  • Sony Master
  • 2,517 Answers
Its not a problem. That's a system of your camera. view your manual book. If there you find that your camera have a small internal battery which is used for memory like date & time then replace it because that have not power to run your camera memory.
Thanks. If your have any doubt then ask me again.
Posted on Feb 03, 2010
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Feb 03, 2010
    Back up battery is different. that use to play your cam. I am talking about memory battery. its stick inside in the camera motherboard. Which is run the date and time continually. Once that the battery are low or not working that time your backup battery start working for it. But when you remove that backup battery that time your camera lost his date & time from the memory. That's why every time when you plug in your backup battery your camera asking for date & time setting.
    Thanks.
Having major trouble setting it after D.S.T. Could you help? The "it" is a Universal TechTronics U.S. Perfect Time clock.
16d25m. \FixYa.com /mm
... I'm not familliar with your particular clock, but, I'm assuming you may have a;
BATTery operated, wall-hanging, 'self-syncronizing' clock with 'hands' on it.
These are often marketed as 'Atomic' Clocks that 'keep perfect time - all the time'.
Generally these work by 'accuratizing' the Minute-hand as it approaches the 'top-of-the-hour' position (e.g. the 60th. or the zero- minute marker at '12'. They often achieve this by either 'double-Clocking' or 'half-clocking' (doublespeed or halfspeeding) the electric pulse that makes the 'SECONDs' hand advance to it's next mark. These 'SynCHRONO-ize' to a low-frequency Amplitude-Modulated (AM) radio-wave signal, (perhaps near 430Khz?) emminating from a source near "The Atomic Clock" out in Colorado (I believe).
One that I used to have hanging had recommended something like the following:
-manually adjust the time (via the small grey wheel near the BATTery, but set it about 7 to 12 minutes 'early' or before the actual correct time, (preferably at about 10 min. before an Hour).
-then remove the one " double A" . . .
... battery (for about 30sec.) and reinstall battery.
-then hang it up, and watch for the second-hand to do its 'Double-clocking' (for part of it's revolutions ) as the Minute-hand apprpaches th '12'. {note; it may take ~2 or 3 hour-cycles for the minute-hand 'to catch-up on all it's "Lost" minutes}.
(then, hopefully, your model will stay 'synchonized' there, for that 'Hour's' setting, and accept It (DST Hour value) with accuratizing Minutes. (and not go crazey over the next few days trying to get back to "Real TIME"). /mm
butifallelsefailsreadthedirectionsand,
basicinstructions'boutlife(on)earth.
Apr 25, 2016 | Home
Lost power cannot set time RC40-A
Hello
Take out the batteries from the unit. Wait for three minutes and reinstall the batteries. Set the time according to its user manual instructions. OK.
Mar 23, 2011 | RCA Radio Alarm Clock
It says set date and time, and it can't record
Okay, then set the date and time first.
This is like a requirement for you to be able to start recording.
For more information, it is still best to consult the manual.
Here is an available one for you to download. Goodluck!
http://www.retrevo.com/support/JVC-GR-D290-Camcorders-manual/id/209bh636/t/2/
Click on get manual, enter the required codes and then finally, download.
Jan 07, 2010 | JVC GR-D290 Mini DV Digital Camcorder
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
Battery removal on 2001 neon
unhook negitive connection then positive connection, then remove hold down bolt and bracket and remve battery, you are going to have to reset clock,and preset radio stations,good luck.
Oct 25, 2009 | 2006 Chrysler Neon
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Setting clock
I think I solved the problem, take out the batteries and reinstall and then reset, seems to be doing ok now.
Oct 27, 2008 | Acu-Rite Audio Players & Recorders
I need to set the camcorder to default settings
For most models, removing the battery pack from the camcorder will restore the default settings; however, some models which contain an EZ Q button, store your settings and removing the battery pack will have no impact on these settings. The Lithium battery maintains the clock function and preset contents of the memory; even if the Battery pack or AC Power adapter is removed. Removing the Lithium Battery along with the Battery pack will restore the default settings.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can't read the date/time
There may be a simple explanation. Here are two possible reasons this is happening: * You may have disconnected the power source before turning off the power to your camcorder. If you remove the power source from the camcorder while the power is on, all settings and selections will be erased. Make sure to turn the camcorder's power off before disconnecting the power source. * This is particularly an issue for some early VHS-C camcorders – those with model numbers beginning with a "6" and ending with a "2" or "3" (i.e. CC6xx2 … CC6xx3). These camcorders have a consumer-replaceable clock battery that may be exhausted. If that battery runs dead or is removed and the main battery or AC is not connected, the camcorder will lose all its Date and Time settings. * In some models, the date and time display is designed to do this. When you turn on many VHS-C and digital camcorders, the Auto Date mode will display the time and date. When recording begins, the date is recorded on the tape for 5 seconds and then disappears. In the viewfinder, the date will then be replaced with the words AUTO DATE but they will not be recorded. They remain in your viewfinder so that you know this feature is on. On full-size or VHS camcorders, the Auto Date feature is very similar. When you first turn on the camcorder, the date along with the word AUTO and a Clock icon appear in the viewfinder. When recording begins, the date is automatically recorded for 10 seconds and then disappears. In the viewfinder, the Clock icon and the word AUTO remain but they will not be recorded. They remain so that you are aware that this feature is on. When using the Auto Date feature, be aware that the time is only recorded when you first turn on the camcorder and begin a recording session. It does not record each time you press the record button. There are a number of time and date display and recording options. Since these vary by model number, please refer to your owner’s manual for more details.
Sep 06, 2005 | RCA CC-432 Camcorder
Weird error message
For Models: CC6254, CC6364, CC6374, CC6384, CC6394, CC9360, CC9370, CC9373 There may be a simple solution. Do the following: * Turn your camcorder's power off, then disconnect the power source (battery or AC adapter). * Remove the clock battery, if equipped with one. * Wait a few minutes, then reinstall the clock battery. Reconnect or install the power source — battery or AC. * Then try turning on the power again.
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
333 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
