Question about M-Audio Maudio USB Midisport 4x4 Multiplatform MIDI Interface - Sound Card
Midisport 4x4 delay problem
My equipment
Windows XP, midisport 4x4 (USB), NUENDO, external midi modules.(not internal), so I don't use sound card latency.
when I start up Nuendo I play the midi controller and it records instanteniously (as it should be), but gradualy the midi recordings start to get delayed . In other words, it sounds fine when I play, but actually they get recorded behind in the nuendo. meaning, if I hit on the perfect timing it will record before the time.
This gradually gets worse, so that in one hour the recording will get behind as much as 1/8 or more. Then I will restart nuendo and it will start all over again, where first it's perfect and gradually becoming bad.
Thank you
  • 123 Answers
Hello Nelson,
What are the specifications of your mace and what is your studio set-up
Have you lookied at performance monitor to see what process is using up all the memory?
If sound like you may have to tweak your machine to suit your specific needs.
I too had similiar problems and tuned my machine to to work more effeciantly...
Posted on Feb 20, 2008
How to connect a MIDI keyboard to computer
There are quite a few ways to do this.The simplest way is to just use the USB port on the keyboard and run that into the computer. If your keyboard has a USB, then you dont need the midi to connect to a computer. You would still use the midi however for other sound modules and items that do have a midi in port however. If you dont have a midi in then you need to get hardware that does as a computer will not have a midi in. There are basic adapters that you can get that just have a midi connector to usb adapter. There are external sound card devices that will do this like the tascam 144. There are also simple devices made my midiman such as the 2x2 midisport that allows you to connect up to 2 midi devices to a computer. The cheapest quickest method if you are just starting out is the midi to usb cable though. Places like walmart, best buy, and radio shack will generally have these. However with making digital music the cheapest is not generally ideal but will get you by in the meantime.If you ever plan on recording audio like vocals or guitar then I would recommend just getting something like the Tascam 144 MK II as it will allow you to input midi, spdif, vocals with phantom power, guitar line in, through it with 24/94 bit conversion, audio drivers, and a bit of software for simple settings configuration. This would be more of an intermediate interface. If you want some pro solutions, then I would recommend going to the pro's at a musician store and talking to them.
May 21, 2012 | Steinberg Cubase SX3
Power leds on m audio omni studio not lit when power on... all othe leds on at same time. Not getting any audio just a loud buzz
you might need to update the software and drivers
http://download.cnet.com/midisport-series-audio-interface/3000-2120_4-35271.ht
The USB MIDISPORT series is M-Audio's line of bus-powered multi-port interfaces. The MIDISPORT line accommodates lots of gear, and its bus-powered architecture provides the option of totally mobile operation. Features include support for multiple discrete MIDI channels and multiple outputs to transmit discrete MIDI channels. The MIDISPORT line requires no external power and has a compact design for mobile or desktop use
l
http://download.cnet.com/m-audio-ozone-dfu/3000-18493_4-73863.html
Oct 04, 2011 | M-Audio Omni Studio Sound Card
I have an error message that says: Error wile trying to synchronize Audio and MIDI Sample Rate 38441 reciognized. Check conflict between GarageBand and external device. Any suggestions?
what you need is a "FULL DUPLEX ASIO DRIVE",which you get with programs like cubase sx, this is like a universal driver which has always synced any audio equipment i've hooked up to my computer, internal & external.make sure it's the full duplex & not the asio4all v2.
But really you shouldn't be having much trouble if your using a USB midi interface.unless your computers sound card is ****.
try resetting the sound cards sample rate to 44100HZ which is the standard rate for most audio,or 48000HZ for digital.
May 16, 2011 | Tascam US122 Audio/MIDI Interface with...
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
Hello I own an mpk 49 keyboard now I'm new at this and I can't figure out if it's internal or external sound the mpk49 gives off. Long story short how do I get the sound out of the keyboard do I have to...
You could look in the manual on Page 5 for connections to external equipment...
Connect a USB cable from your computer to the MPK49. The unit will be powered through the USB connection. Alternatively, if you do not wish to use a computer in your setup or if you wish
to power the MPK49 externally, please plug in a 6V-1A DC power adapter.
2. If you would like to use an external sound module, connect a 5-pin MIDI cable from the MIDI OUT of the MPK49 to the MIDI IN of the external device.
3. If you would like to use another MIDI controller in your setup, connect a 5-pin MIDI cable from the MIDI OUT of the controller to the MIDI IN of the MPK49.
On Page 13 the first of the FAQ's is:
Question: Does the MPK49 have internal sounds?
Answer: No. The MPK49 is a MIDI-controller, which means that it does not contain any sounds inside but is instead used
to control external sound devices, such as hardware and software synthesizers, sequencers and drum machines.
If you lack the manual you can go to retrevo.com and download it for free after you register.
Feb 02, 2010 | Audio Players & Recorders
Midiman Midisport 4x4 USB freezes
well, all you need to, the midiman need chances you to chance it, try another one
Dec 04, 2008 | M-Audio Maudio USB Midisport 4x4...
Problems with reasons 4 in mac book to be recongnized
did you install the UB drivers? And which version of the drivers? Which os are you running?
keep me posted.
Nov 13, 2007 | M-Audio Maudio USB Midisport 4x4...
Not communicating...
It would help a lot if you had another Midi device to try. Then you could narrow down the problem.
Another thing to try is to download some simple piece of Midi software such as Bome's Mouse keyboard (free 30-day evaluation) and see if you can get that to work (using your mouse on the screen keyboard to trigger notes on your MIDI keyboard). You may get further clues by trying that.
Oct 12, 2006 | M-Audio MIDISport 2x2 MIDI Adapter
M-Audio Maudio USB Midisport 4x4 Multiplatform MIDI Interface - Sound Card Logo
177 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
