Question about Microsoft Xbox 360 Console
Swapped Hitachi boards now have "Put disc into xbox 360 console"
Original problem was No disc error, or couldnt read disc, I swapped board from my old GDR3120 to new Gdr, but now am showing "to play put disc into xbox360 console"
  • 1 more comment
  • gloryboy78 Feb 03, 2010
    Turned sata around but still no luck, guess i will problay have to flash key, it plays dvd in newdrive/old circuit board drive, but not games. Read that circuit board swap would work but it didnt for me,its just to simple to mess up, but I did notice when it was first powered on thatthe xbox flashed red a few times,
  • gloryboy78 Feb 04, 2010
    This was a 3120L 047dj replaced with same bought new, i am going to try the laser tonight and see what i come up with thank you very much for info
  • gloryboy78 Feb 08, 2010
    no luck with old lazer and drive so i put board back in new drive, now have "open tray" game or no game in console, thanks for the help, but going to junk it.
  • 340 Answers
Have you put the sata cable from your drive to your motherboard in upside down? if your not sure turn it around and see if it works.
Remember thumbs up if this works.
Posted on Feb 03, 2010
Testimonial: "I wouldnt of expected the laser would need adjustment, great options i appreciate it."
  • damonumber5
    damonumber5 Feb 04, 2010
    Was the new drive new or new to you, you have to use the same version or newer the older versions won't work, if its not that this sounds like a laser issue on both not a drive key issue,you can change the laser strength setting, if you want to give it a try on your original one,replace the key, there are 2 very small screws on the back of the laser, mark the top of the screws with a marker pen, then turn screws a quarter of a turn left,see if this works, if it does not, turn back to centre than try a quarter of a turn right, if this don't work you have not lost anything because you would have scrapped that drive anyway.
    Comment or thumbs up if this works.
I've got an older style XBOX 360 that quit playing game & movie discs.
The diode in the lens has gotten too weak to put out enough voltage to read the game discs. I'm assuming that you have the original drive board still in your system.
you can find another lens on eBay really cheap, here is 3 links because the x box 360 consoles use 2 different lenses. On one of them the connecter for the worm gear mounts on the top, the other mounts from the bottom of the laser
http://www.ebay.com/itm/Microsoft-XBOX-360-SF-HD67-Optical-Laser-Lens-Replacement-New-Repair-Part-/290632695270?pt=LH_DefaultDomain_0&hash=item43ab0efde6
or this one
http://www.ebay.com/itm/NEW-XBox-360-Laser-BENQ-VAD-6038-Lite-On-DG-16D2S-/130511988685?pt=LH_DefaultDomain_0&hash=item1e631ee7cd
Nov 15, 2011 | Microsoft Xbox 360 Console
Alright, So I have 2 xbox's witht he rrod. I took them apart. and accidently put the wrong disc drives back in the system. so i swapped it out, and now the original disc drive doesnt work with it either....
If you replace the same drive with the same P.C. board back in
the original console you should be good .Provide that the drive is
or was good before you took it apart ( read games) also when
attempting a generic fix it kit ( washers and screws ) and over
heating G.P.U. you can create new problems .What ever you do
DO NOT GO ON LINE with a different drive or your console you
will be band for LIFE !! If you wear successful with your repair
your drive should boot right up . a good drive in the wrong console
will post a white screen to put a 360 game in the console.
Did you just replace the heat sink compound or do a full x clamp
mod ??
Rob
Mar 13, 2011 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Everytime i put in a game in my 360 it says open tray
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Mar 17, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Get the error message put disc in 360 console and will not play games but will play dvds and music.
If the console has not been opened and the drive changed then you will need to replace the laser. I repair these problems often with 99% success rate.
Jan 24, 2010 | Microsoft Xbox 360 Console
Xbox 360 cd drive comes up with please insert disc into an xbox 360 cd drive no matter what game i put in all the games are brand new and are xbox 360 games, the drive has not been change or altered the...
This is going to be a bit long -- but very detailed, so please readit carefully. There are several reasons that an xbox 360 system willhave problem reading discs. The error messages also vary fromunreadable disk, no message at all but the game skips, "please insertdisc in a360 console" to "open tray." There are a few reasons this mayhappen:
1.Bad disc. Check the back of your disc for scratches.If it looks good(or plays fine in another console), then the disc isprobably fine.Also-- try more than 1 game to be sure.
2. Badlaser. The XBox360 has a DVD drive very similar to a PC's DVD driveinside. The drive contains a bunch of parts including a few motors andgears and a laser.The laser is the part that actually reads the disc.The reality is...with all the hours and hours of gameplay, lasers doeventually wear out. The laser isn't very easy to replace, but it isreplaceable. You can find any and all XBox 360 lasers at the followingwebsite:
3.BadDVD Drive. Sometimes other components inside of the DVD drive can becomebad such as the motor that spins the disk, the motors that open thetray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360'sDVD drive is tied to the motherboard using a software lock.The easiestway to overcome this lock is to buy the exact same manufacture DVD drivethat is in your system now, remove the circuit board from the old DVDdrive (which contains the software key) and transfer the circuit boardinto the new DVD drive that you purchase. If you do this simpleprocedure, there is no flashing involved. The following website carriesDVD drives and also provides instructions on swapping the circuit boardfrom the old drive into the new one.
Nov 18, 2009 | Microsoft Xbox 360 Console
Xbox 360 not reading discs
Nov 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
DVD Rom replaced
When you switch the original dvd rom to a replacement. you MUST remove the logic board from the original drive and put it into the replacement drive for it to function
Apr 19, 2009 | Microsoft Xbox 360 Pro System Console
New hitachi drive wont play any discs
your firmware from the original drive became corrupt,
dig in some of the lead tech/mod forums to see what you can do about that.
Aug 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
96 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
