Display is flashing f21
I started a load of closthes, and when i went to check on the amount of time that was left, the display is flashing f21
  • 5,911 Answers
If this is a Kenmore Elite or Whirlpool Duet series washer, "F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Feb 03, 2010
Won't finish cycle 21 F- flashing on panel
F21 error code is indicating that it is taking too long to drain water.
Your details indicate that you are using too much detergent or the wrong type of detergent and causing excessive suds. The drain pump can not pump suds out. The washer requires HE (High Efficiency) detergent formulated for front loading washers.
Cut back on the detergent and it will most likely operate correctly.
NOTES:
* After four (4) minutes the "Sd" error will be displayed, and then four (4) minutes later the "F21" error code will be displayed.
* Press STOP two (2) times to clear the display.
Possible Causes:
- Using too much High Efficiency (HE) detergent and causing too much suds.
- Using NON-HE detergent causing too much suds.
- Kink in drain hose
- Debris or foreign objects in drain pump filter.
The drain filter is located behind the lower access panel.
NOTE: Disconnect the power cord before removing the lower access panel and cleaning out the drain pump filter.
Remove the two screws (key#21) securing access panel. The filter cap (key#14) is removed by turning it counter clockwise. NOTE: Be sure that all the water has pump out before removing the cap. Have some large towels handy because there will be water coming out the filter/pump once you remove the cap. Check and clean the filter and remember to reduce the amount of detergent and the washer should perform as designed
Hope helps (remember to rate and comment this free answer)..
Jun 10, 2011 | Kenmore HE2 Plus Front Load Washer
The machine washes for a few minutes and stops with F21 flashing below the time remaining ,the door is locked and it doesn't restart
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Apr 07, 2011 | Maytag MHWZ400T Front Load Washer
My machine will not finish load. it flashes the f21.. i unplug it it goes to 85 minutes. i reset it to rinse and spin. remove the 2nd rinse. sometimes it goes through sometimes it doesn't and goes back...
The F21 error code is displayed when the water didn't drain in the normal time,the usual reason the washer did nto drain with in the normal time is because the filter screen on the pump is clogged. This tip i wrote will show ya how to take apart the washer and clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Mar 29, 2011 | Kenmore HE2 Plus Front Load Washer
F21 is flashing,... what is this
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
F21 washer drain time exceeded
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE2t front load washer model #11047561604 serial # HLY1661717 I'm trying to wash a load of clothes and it's giving me a message F21 and it is flashing, I un- plug the washer and try to...
The F21 error code indicates a long drain. Here are some tips that should help you resolve this problem:
  • Check your washer drain to make sure that it is draining properly.
  • Check the drain hose for kinks and clogs. Make sure that it is installed properly per the instructions in your owner's manual. An improperly installed drain hose can prevent the washer from draining properly.
  • Check for excessive suds in the washer tub. Excessive suds can prevent the washer from draining properly and will result in the F21 code. Make sure that you are using the proper amount of HE (High Efficiency) detergent to prevent excessive suds.
Remove any clothes and then use a wet/dry shop vac to drain any water out of the washer.
Arrange shallow pans and/or towel in front of the large item filter shown in the second image below to catch residual water when you remove this filter.Remove the large item filter as shown below. It is likely that you will find a clog in this area that is preventing your washer from draining.
If you do not find any clog or restriction in the large item filter and none of the other issues discussed above apply to your situation, then you could have a failed drain pump. If the pump is damaged and will not pump out water then it will need to be replaced.
Aug 17, 2010 | Kenmore Washing Machines
What is an F21 flashing? My washer will not turn off or anything. It is humming and flashing F21. Thanks
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
Thank you !!
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
WASHING MACHINE FLASHING F21
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
kinked.
Aug 18, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Washer won't drain completely. All lights flashing. F21 code is flashing.
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 24, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
