Question about Car Audio & Video
Im trying to put a after market radio in a ford taurus 92 gl wagon
  • 3,230 Answers
Well you can please follow the below steps -
1. Open the hood and disconnect the negative battery cable from the terminal. Ensure the cable is secure to keep it from touching any metal parts (because it causes earthing problems).
2. Cut a wire coat hanger into two 8-inch pieces and bend them into a "U" shape. Locate the locking pin holes, two on each side of the stereo, and adjust the hangers to fit on each side. Push the hangers into the holes and apply pressure towards the outside of the head unit until you hear the tabs snap into place.
3. Pull the stereo out of the dash and disconnect the wires from behind the unit. Secure the new head unit into the Ford radio adapter kit.
4. Connect the wiring harness adapter onto the old harness and plug the connection and antenna wire into the back of the new stereo. Push the radio assembly into the Taurus dash taking care not to kink the wires. Listen for the pins to snap into place.
5. Secure the negative cable to the battery and turn the stereo on. Test the speakers and controls to verify they are working properly. Please post comments if you need more help or information.........
Good Luck!!
Thanks
Posted on Feb 03, 2010
How do I find the electric ignition switch on my 1993 Ford Taurus gl station wagon
where you put your key in to start vehicle is ignition switch -to find and buy one ---junkyard --dealer --online search
Sep 28, 2016 | Ford Cars & Trucks
Where on a 1991 ford taurus wagon is the key code for the ignition
Replacement Ignition lock cyclinder for 1991 - Taurus Car Club of ...
www.taurusclub.com > ... > Maintenance and Repair
May 21, 2014 - I have a Ford Taurus 1991 6cyl 3.0L. I am looking on the RockAuto site. ... Drives: '90 Taurus GL Wagon 3.0L; '65 Rambler Ambassador 990 convertible ... I have the key code for the Ford, but do not know how to relate it to ... Ignition Problems
Apr 9, 2012
Lost Keys
Sep 24, 2006
Ignition Problem: Car Wont Start & Key's Loose?
Apr 25, 2006
Programming Pats, Keyfobs, & Keyless Entry
Jul 7, 2004
More results from www.taurusclub.com
Ford Keying Systems - How They Work - Taurus & Sable ...
www.taurusowners.com > ... > Maintenance & Repair
Jul 22, 2013 - 5 posts - ‎4 authors
The square-head 10-bit key operates the ignition and door locks, and the ... I believe the first three digits are the ignition code and the last three are the door code. ... 1992Ford Taurus GL wagon - 232 - sold, was later wrecked ... --Beige 1991 Mercury Grand Marquis LS Colony Park Wagon ' 5.0 V8/AOD ...
Ford 10 Cut Ignition Svc. - YouTube
? 13:45
https://www.youtube.com/watch?v=r6mposGhsuI
Sep 23, 2010 - Uploaded by William Mcintosh
Ford, 10-cut ignition removal and new ignition installation process. ... I have an 91 windstar, lost key and ...
Dec 12, 2015 | Ford Cars & Trucks
Car dies after 30mins of driving without turning motor off. replaced coil module, fuel filter, fuel pump. 94 ford taurus gl wagon, 3.8liter engine
I have the same problem few days ago, and still didn't find any solution. Can any one please help?????21
Jul 28, 2011 | 1994 Ford Taurus
I need a new Trans for a 1996 ford Taurus GL wagon.
The best way is to use the vehicle VIN number, here is a link to a Ford Vin Number Look-up site, that will tell you the transmission code and the type of transmission you have:
https://www.fleet.ford.com/maintenance/vin_tools/default.asp
May 23, 2010 | 1996 Ford Taurus
1994 Ford Taurus GL 3.8L engine battery light flickering
Sounds like the regulator might be going bad in the alternator.
Apr 03, 2010 | 1994 Ford Taurus
Im trying to locate the fuel filter on my ford taurus
it should be near the tank, if you cant find it, maybe you should not replace it, special tools are required.
Sep 21, 2009 | 1995 Ford Taurus
96 taurus wagon goes to neutral when vehicle comes to full stop.
That would be your neutral park switch is bad or broken. If the shifter linkage is not aligned with the neutral park switch it will not work properly. Located on drivers side on top of Trans.
Mar 22, 2009 | 1996 Ford Taurus
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
