Question about HP Pavilion dv9000z Notebook
Hi, My HP shut down unexpectadly. Now every time i try to turn it on it gets as far as the bios info then shuts down. i had someone look at it and they say its not the battery or ram, but from what he's read it could be a problem concurrent with the model. Any ideas?
  • 458 Answers
Our Dv9000 is suffering from A Faulty Video Chip...
I do Post A Do It Yourself Repair Method If You Want to Attempt To Repair It Yourself... Otherwise You Will Need To Replace the motherboard to correct the issue... Motherboard replacements For the dv9000 series will average $230 double that if you send it in to HP....
Check Out My DIY Method at...
http://www.wnycomputerpro.com/store/index.html
Posted on Feb 03, 2010
I have an HP Pavilion 8113cl the problem is power. Starts just fine til window screen appears then shuts off. I can go into the bios sut as soon as it displays the machine shuts off. I've tried other
a notebook
well take out the battery , large one
run ok now/.
if bios does dead, that is POWER iSSUES.
BIOS never goes dead unless
1: POWER LOSS. (battery it does, try a new power pack )
2: OVERHEATED. clean out the dust lint yet?
3: Or far worse... (lots)
Jun 28, 2017 | HP Pavilion Computers & Internet
My hp 1630n keeps shutting down for no apparent reason. sometimes it goes all day then shuts down, sometimes for 10 mins. it isnt running hot either. replaced power supply with one that is 400w and it...
This might be an indication that a hardware is failing. go to BIOS and leave it turned on, see if it will still shut down randomly. If it does, then it is definitely a hardware problem. If it still under warranty, call HP for support. You can also visit HP Support Website for more info.
If it is hardware problem, try isolating it by re-seating the parts which has an integrated chip like RAM, VIDEO CARD and CPU. If you have two sticks of RAM, try each one without the other and see which one is failing. You can also switch to the integrated video if you have one to test the graphics card. Make sure you have the proper knowledge on how to handle these parts as this might cause damage on the computer and electric shock.
Mar 23, 2011 | HP Pavilion a1630n PC Desktop
Hi, I have a hp mini 110 notebook. It just shut down on me last night. When I re-booted it it starts off normally with the hp logo and the F9 - change boot device order F10 - BIOS set up options this...
1.first thing we can do is shut it down
2. turn back on immediately and continually hit the f8 key
3. boot into safemode with command prompt
4. if you have windows vista goto run > type in command prompt
5. chkdsk /f
hope this helps please vote if this info was useful, if any other problems or still having trouble please let me know thank you.
Feb 18, 2011 | HP Mini 1000 Netbook
I have an Acer aspire 7738G laptop that shuts down from heat
try updating your video drivers, or reverting back to older drivers.
May 23, 2010 | Computers & Internet
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Restart doesn't work
need more info but pc's usually do this if you
havent registed windows and your time limit to do so is up.
you can install os again and register if
thats the case
Jan 02, 2009 | HP Pavilion dv6000z Notebook
Can anyone help?
Sounds like your power supply may have died. Check all the power connections to your pc (if it is connected to a power-bar, make sure the power bar has not gone bad). If everything looks good there, you probably need to by a new PSU (Power Supply Unit)
Apr 06, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion dv9000z Notebook Logo
161 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
