Question about Kitchen Ranges
We have a kenmore electric range/oven..model 790.46994. after baking dinner tonite, we left the stove on..or it may have turned itself on by itself. either way, we tried flipping the power breaker and turning it off. then we hit the breaker and immediately the oven began heating back up again. i tried holding cancel/off for a few seconds, and the door locked...so now the door is locked, the oven wont turn off unless we flip the breaker to and it keeps giving us a message on the screen that says ''F1'' please help, thanks. any kind of reboot on this thing? or is it a short? thanks, -james
  • tpg1 Feb 15, 2010
    what did you do...mine did the same.
  • jaymzsun Feb 15, 2010
    ack...ok...im going to type this again.
    so we turned the breaker off for the whole nite so it totally cooled down.
    then in the morning i turned the breaker on while someone was right next to the oven. as soon as it turned on(before it had time to heat up and do its thing) he hit the bake button then turned it to 400. and as soon as the oven preheated to 400 the oven turned off.
    when i was researching i found that f1 meant either the computer/controller module was bad(which doesnt seem to be it) or it was an old heating element(the metal piece on the bottom of the oven that turns red hot) and the element was grounding out. so our best guess was that the oven was so dirty that it was causing the element to ground? maybe not though. i think the oven was running pretty damn hot the night before before we figured it out like it was running a cleaning cycle. so maybe the oven cleaning burned off the gunk that could have been grounding the element. not totally sure if that was it though...either way, try turning it on when it is totally cooled down, and try hitting bake and preheating to 400deg.
    maybe it was a glitch and we just tricked the computer.
    cheers,
    -james
    happy baking
  • 149 Answers
You have an electronic oven control failing EOC pannel may need changing. but check wire to and from it
Posted on Mar 27, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
How do I change a fuse in stove model 55612?
Most stoves do not have fuses in them. Your house electrical box controls the electric to the stove
Sep 29, 2014 | Kenmore Stove / Oven / Range Bake Element...
Loud pop and light behind stove. Stove top works, oven does not.
Good Morning Stephanie - Typically you may locate the model and serial number in the storage drawer, on the right side. Based on the symptoms you are describing, you may either have a communication error from the main control board or a faulty bake and/or broiler element. If resetting the unit did not solved the issue, at this point I would personally contact a professional to accurately diagnose the range to determine the root cause to reduce the risk of unnecessary parts.
May 26, 2013 | Frigidaire FEF316 Electric Kitchen Range
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
Soot from my gas oven
Have a Whirlpool Continuous Cleaning Oven It left soot on the top of the stove after baking the other night why ?
Nov 25, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Just not workin
maybe a loosing wire. move the stove , disconect power and take the cover and look for a loosing wire at the bake element or a burning bake element
Apr 22, 2008 | Kenmore 96213 Electric Kitchen Range
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
399 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
