Question about Yamaha RX-V2500 Receiver
Just stopped working.Doesn't power up you can smell that burned smell.When you push the power button you can hear a little fizzle noise.
    Brigadier General:
  • 8,546 Answers
This isn't something we can help you with. Keep a fire extinguisher handy if you want to keep messing around with it. It needs hands- and eyes-on by a pro.
Posted on Feb 03, 2010
Hello all, there is something wrong with my washing machine. During a wash i started to smell something like burned tire so i stoped it. Now everytime i try to start a new wash it looks like it starts but...
check the belt inside of the machine that's a problem so it seem like it is loosing because of expanding so replace it with a little lower size or adjust it by loosing the motor and push it to side.and makesure not tighten toomuch because you may demage the motor and don't loose it toomuch.
Nov 04, 2013 | Washing Machines
Just stopped working. No burning smell. When start button pushed, some kind of tiny "click" sound heard around the timer.
The click is most likely the timer motor moving the dial on the timer. The motor circuit on American dryers is 120 volts whilst the heater requires 240 volts to operate its 5k element. The motor circuit always has the fuse in it. The heating element has limits mounted on it but they only kill power to the element and not the motor. Fuses are usually located on the blower housing next to the control thermostat. MORE HERE
Nov 29, 2012 | Dryers
Heater and aircon not working,loud rattling noise and smoke from vent,now not power to fan
It appears your fan itself burned out. When a field coil of an electrical fan burns out it usually makes a lot of smoke. The noise could be something that fell in there that stopped the fan from turning freely. I can imagine it heated up under the strain and burned out.
When you restarted it was burnt out so hence no noise and no fan.
The smell of the smoke should also be clue. Electrical field coils burning has an awful soury type of smell.
Aug 13, 2012 | Peugeot Partner Cars & Trucks
Push start button and it makes the noise like its going to start but stops when you release the button. Drum doesnt turn, smells like it might burn
my knemore want start i push the button it make a noise but it want start, if i hold the button down it goes quiet.
Nov 20, 2010 | Frigidaire Dryers
Burning smell, Loud noise when start button and doesn't turn on
Belt, and skid plates very easy to change and not much money
Aug 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
High pitch noise, no POST
it sounds like it has died and blown up (last time that happened to me it smelled bad too.)
Jul 14, 2009 | Computers & Internet
SDM M51 major problem
Based on your post/description, the "fizzling noise and a smell of ozone" are indicators of electronic component(s) that burned. Should you be comfortable and have a fair knowledge of component level repair, soldering and the use of a VOM then it is possible to repair it yourself. The inside would basically be divided into 3 electronic group; 1. power supply; 2. video; and 3. illumination. This should be fairly straight forward since the "fizzling noise and a smell of ozone" indicators would also be visually apparent. Fizzling would normally be capacitors leaking their oil at high temp/high pressure. this would probably be in the power supply section (but the other 2 groups have their own capacitors also). Smell of ozone would usually come from high voltage arcing which is only present in the inverter circuitry of the illumination. It is the group responsible for supplying the high voltage high frequency supply of the small fluorescent tube (CCF) that provides the backlight of the display panel. As earlier mentioned, it has also its own capacitors. If for some reason you do not feel comfortable opening and working the electronics inside, you might be better off seeking the services of a qualified professional. Good luck and kind regards. Hope this gives you and idea and how to go about it.
Aug 20, 2007 | Sony SDM M51D 15.1" LCD Monitor
Open Questions:
See all Yamaha RX-V2500 Receiver Questions
Yamaha RX-V2500 Receiver Logo
182 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
