Question about Zenith XBR413 DVD Recorder
Unit is in safe mode - Zenith XBR413 DVD Recorder
  • 1 more comment
  • metaylor Feb 03, 2010
    I did that but the safe mode continues reset itself,itmaybe fine for 10 minutes it maybe fine for an hour but it always comes back.When I use the remote it alternates between on and off.For example when I press any key on the remote it sets itself to safe mode when a press the remote again any key the safe mode is off.It works better manually then when i use the remote. The remote is essential but the remote won't operate the unit at all,it just turns the safe mode on and off.
  • metaylor Feb 04, 2010
    It is the original Zenith remote.That came with the unit out the box.
    Okay Thanks
  • 10,515 Answers
On Most Models, by Holding the Power Button for 8-10 Sec would Fix this. One of the User's also describe that if there is a Button states ' Child Lock ' on that. Press it for few Seconds and the unit would be out of the Safe Mode.
If Problem remains, let me know so that i could search more for this Model.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Feb 04, 2010
    Thanks for your response!!
    Kindly tell me, Are you using an Original Remote or Aftermarket One? Let me know the Make and Model of the Remote?
    Hope i helped you.
    Thanks
  • taran_2005
    As you are using original remote as well, i guess it would be a problem with Mechanism which needs to be taken care by the Tech on Site.
    As you reside in Chicago, i could refer :-
    http://www.yelp.com/search?find_desc=tv+...
    There is a list of People. Call them and ask for the Quote before you send the Unit for Repair.
    Hope i helped you.
    Thanks
  • taran_2005
    Do not Forget to Close the thread by Accepting my Solution, if 100% Satisfied.
    Hope i helped you.
    Thanks
Its on safe mode
run first to safe mode and then restart the unit... this is a system error not in the monitor..
Dec 09, 2013 | Gateway FPD1975W 19" LCD Monitor
SAFE
SAFE is the same as PROTECT in other models. It means that an incorrect voltage has been detected, and the unit has been forced to safe mode (forced standby) to prevent further damage to internal component.
Safe mode can be triggered by a bad connector as well as by a blown component inside the player. Check all cables connected to the unit and disconnect power cord for about ten minutes. If that does not work, then the player must be repaired by a technician or replaced.
Combos are getting more and more expensive and difficult to find. This kind of unit is usually worth repairing.
Try first the general troubleshooting steps suggested above. Here a link resuming the basic procedure (protect and safe mode are the same): Unit in protect mode.
Regards.
Ginko.
Jan 26, 2011 | JVC HR-XV2 DVD Player/VCR
How do i turn off safe mode
Most computers when you boot it up give the option of "Boot Menu" upon the first few seconds of powering the machine on. Look at the screen and see if it reads Press F1 or F2 for Boot Menu. From there you can toggle off the safe mode option. Sometimes it's the delete key or alt key for some other computer providers as well.
Hope this helps,
Marty
Nov 27, 2010 | Computers & Internet
How do i remove the remote from safe mode?
Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
1. Ensure the Remote is in "Safe Mode Requested" by taking out the batteries, and disconnecting the remote from the USB cable.
2. Hold down the Off button and plug the remote into the USB.
3. Continue holding down the Off button for another 10 seconds. The remote should then display the words "Safe Mode Requested".
4. With the unit in "Safe Mode Requested", re-install the firmware by clicking Support on your home page.
5. Click Firmware in the Downloads section and follow the online instructions to upgrade the firmware.
6. Once the firmware upgrade is complete, click Update My Remote.
7. Insert new batteries into the remote.
Jul 27, 2010 | Logitech Harmony 659 LCD Remote Control
My car audio has gone into safe mode need codes to unlock it. vauxhall corsa sxi
Hi.
There is no code to unlock safe mode. Safe mode means that a fault has been detected and the unit goes in this mode (kind of forced stand by) to prevent further damage.
Disconnect battery ground cable and check the wiring at the back of the unit, a contact in the connectors or a short on wiring is common cause for safe mode.
When you disconnect the battery ensure that you have the anti theft code if needed. Anti-theft is different from safe mode. In that case you get Code on display, not Safe or the triangle sign.
Regards.
Ginko.
May 31, 2010 | Car Audio & Video
Remote is in safe mode
You can try this solution to your Harmony 550 Safe mode problem:
Harmony 550 Safe Mode Fix Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
Hope that helps.
Aug 18, 2009 | Logitech Harmony 550 Remote Control
Can Not Boot Into Safe Mode
you can usually get into safe mode by powering on the unit to desktop then holding the power off till the unit powers off then on startup it should give you an option for safe mode.
Jan 13, 2009 | Computers & Internet
Safe mode
NOTE: Ensure the new batteries are all the same brand.
Nov 26, 2008 | Logitech Harmony 659 LCD Remote Control
Unit in "safe" mode
Try pressing the stop button the front panel of the unit and holding it in for 5-10 seconds.
you may also want to try it on the remote.
Jan 13, 2008 | Zenith XBR413 DVD Recorder
Stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
Oct 29, 2007 | GoVideo DV2150 DVD Player/VCR
Zenith XBR413 DVD Recorder Logo
53 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
