Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washing machine the drum is shaky and makes a lot of rattling noise when washing
    Problem Solver:
  • 9 Answers
It might be a bearing, or it might just be something inside the drum!
If the machine is not exceptionally old it shouldn't be a bearing.
It might be limescale!
You can access and inspect the drum from the outlet.
Heres what to do:
Disconnect the machine from the mains and the water supply and pull it into a clear area.
Put a thick cloth on the floor and gently lay the machine on its left hand side, looking from the rear,
Undo the small panel on the back and you will see the black rubber concertina hose, pressure chamber and pump, which are now all easily accessible from the rear and the botom of the machine.
Undo the circlips with a screwdriver and pull the hose away from the drum. You will now be able to see the element and the inside of the drum.
Check it for debris and limescale.
At the same time clean out the filter with its "ping pong ball" and plastic pressure chamber.
THis will clear out any loose items and let you check to see if the drum needs descaling.
Job should take about 20 minutes!
Posted on Feb 29, 2008
  • firesign Feb 29, 2008
    I forgot to say if the problem is a loose item you may need to stand
    the machine upright to let them out of the outlet hole before reitting
    the hose!
Why is it rattling and making very loud noise when going into spin and bits of rubber on wash
make and model might help but if its fine grey rubber or type of plastic it could be the drum dropping either because the inner bearing has broken or the drum spider has cracked
Apr 17, 2016 | Washing Machines
Problem with Washing Machines Something stuck /rattling in washing machine plastic divider Inside drum
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 02, 2013 | Washing Machines
How do I stop my aav 8000 washing machine from making a rattling noise in spin cycle? It's on level ground ;-\ I disassembled some of the washing machine and the noise is coming from a metal par
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | Admiral Washing Machines
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Making noise when running
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Instructions: 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. 2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) 3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. 4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. 5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. 6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Feb 09, 2011 | Washing Machines
When on spin,the drum is rattling and making a lot of noise
More than likely the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough, or is rumbling or grating, then the bearings have failed.
Dec 03, 2010 | Hotpoint WMA58 Front Load Washer
Foreign object stuck between drum and casing
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Rattling
Level the drier, check the drum for foreing objects, check your belt and replace if need to. Check your rear drum seal, and your drier idler pulley, and replace if need to.
Jul 05, 2008 | Kenmore 98702 Stacked Washer/Dryer
Bauknecht Washing machine
the bearings seem to be gone in drum
Dec 18, 2007 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
71 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
