Question about Motorola Mobility Bluetooth Headset-Silver/Black Headset
My Blackberry is asking for a code to pair with my H700C headset?
My h700c bluetooth is not pairing with my blackberry. have not used it on this phone and its asking me for a code. Ive had this for years so i dont have any packaging. What do i do? Where can I find the code?
    Guru:
  • 437 Answers
Enter the code 10 times false, then your phone will reset himself and let create new one.
Posted on Feb 11, 2010
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to turn on Motorola H700C wireless bluetooth headset
If you haven't figured it out by now, you have to push and hold the button down until it starts flashing.
Just a simple push of the button will not work.
If it's not connecting to the phone then you haven't paired it to the phone.
Pairing must be done for it to work.
The instructions should be with the headset.
Oct 25, 2010 | Motorola Mobility Universal Bluetooth...
Won't stay connected.
check the batteries on the BT headset
May 15, 2009 | Motorola Mobility H700 Wireless Headset
I can't sync my motorola h700c with my blackberry
1. Bluetooth enabled?
2. Options -> Bluetooth -> Add Device
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
How do I connect my H700C?
usually it's pretty simple, you have to turn the h700c on, usually it's by holding the button for few second untill you get the blue light on permanent for a few seconds, now go to your phone and look for the blutooth settings, now you should have an option find other devices. after your phone found the headset you'll have an option "connect" or "pair" or somthing from that kind.
And that's it
Hope this helps
don't forget to rate
All the best
Tom
Apr 10, 2008 | Motorola Mobility Bluetooth...
Motorola H700 Bluetooth connection problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Apr 01, 2008 | Motorola Mobility Bluetooth...
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Motorola h700c
Hold the mutifunction button with the mouth piece close, until it turn purple, then open the mouth piece so that it will stay in the pairing mode. Now go ahead and have your phone or blackberry search for H700c
Good luck
Dec 13, 2007 | Motorola Mobility Bluetooth...
Motorola Mobility Bluetooth Headset-Silver/Black Headset Logo
313 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
