Question about Acer Aspire 5100 Notebook
Lcd disolay has liens through it and colors are off.
The display is jumpy and has lines flicking through it.. When connected to external monitor..no problem exists
    Scholar:
  • 101 Answers
If tapping the screen (on sides or back of case - not the screen itself !) affects the display it is usually loose connections either at the motherboard or behind the display where ribbon cable connects. relatively easy repair for someone who can take apart a laptop but you need the repair manual because there is a sequence that needs to be followed.
Posted on Feb 20, 2008
My fujitsu U9210 not connects with external monitor
Max. resolution external display 1920 x 1200 / true color / 60 Hz
graphics brand name Mobile intel gMa 4500M HD
You need to set screen resolution to this if your monitor will take it.
Apr 04, 2014 | Fujitsu Siemens ESPRIMO MOBILE U9210...
My dell studio laptop monitor's background colors are a mess. They are shifting colors, blotchy, and running. Please help! Thanks in advance
Don't know which model Studio you have but look to see if you have a 15 pin VGA plug on the laptop. You can connect an external monitor to determine if your computer LCD display is bad or the video circuit.
If the colors look normal when attached to external monitor, then you have a problem with the laptop's LCD display panel. If the colors are still distorted then your video circuit inside the laptop has a problem.
Feb 18, 2011 | Dell Computers & Internet
Screen is black, shows no image. Sometimes it flicks and sometimes presents a lot of horizontal colored lines. Once or twice the screen worked for a couple of seconds, saw the windows' logo and then it...
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Feb 08, 2011 | Toshiba Satellite L305-S5875 Notebook
When turned on (either with battery only or with both battery and utility power connected) the laptop displays nothing except a blend of colored vertical lines. And, it doesn't seem to power up at all,...
Hello
Plug in an external monitor. If the external displays fine, then the video card is also fine. Gently pinch the edges of the LCD screen where the lines terminate. If the lines change or go away, then it needs a new LCD screen.
Good Luck,
Dec 22, 2010 | Fujitsu 16'' LifeBook N7010 Laptop PC w/...
It displays colorful lines on the monitor...cant see nothing
Test your laptop with an external monitor and find out if the external video goes bad too. If both, internal and external images go bad, you have a problem with the video card.
If external works fine and only internal goes bad, most likely it’s either bad video cable or LCD screen failure.
May 21, 2010 | Nvidia GeForce 7200 Graphic Card
Power stable however no display, the lock keys flick and the bluetooth symbol always on.
no display after switching on the laptop?
1. try to connect to an external monitor using an analog video cable. monitor is on. turn on laptop after a minute press and hold on Fn key then press F8 at the same time to toggle the display between LCD to Monitor, if nothing happened do step 2.
2. turn of laptop. remove video cable. press and hold D key then press power button at the same time. this will test the LCD. check if there are colors display. if yes do step 3, if no replace lcd and lcd cable.
3. make sure laptop is off. press and hold on the Fn key then press power button at the same time to run a quick test. Even no display or anything wait for about 5 minutes check if you will hear series of beeps. If yes.replace video card if it is expansion, replace motherboard if it is integrated.
Sep 24, 2009 | Dell Vostro 1510 Laptop
Horizontal lines on ASUS laptop screen
HI friend
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is Motherboard problem Please contact Your nearest service centre for Service.
Jul 15, 2009 | ASUS VW222U Monitor
IBM t42 Display problem
Sometimes there are keys are your laptop that adjust your settings.
If you know which keys you can hit the fn key simultaneously.
If your not sure go on line and you should be able to find a site that will tell you how to adjust your screen.
In search type your laptop model then type display settings
Jan 12, 2009 | IBM ThinkPad T42 Notebook
Acer 5100, Lines throughout screen!!
connect to an external monitor, if it works fine then it is the monitor, if not its the video card.
Dec 11, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
