Coleman Evcon AH Series heat pump and the status light blinks
I have a Coleman Evcon AH Series heat pump and smoke came out of the ducts and set the smoke alrms off. I checked the status light and it is blinking twice indicating an overload. I checked the resistance of the heater coils and ''Heater 1 '' is open. I need to replace the heater coil. But the status light is still blinking. Can I reset it to get until I can get a new coil?
  • 12,061 Answers
NO you cannot. I also advise you to completely disconnect all power to it until ready to do the work, you may cause a fire otherwise. Be safe.
Posted on Feb 03, 2010
Flame sensor
Chances are there is a problem with the heating circuit. The blinking light is representative of identifying a problem. Look on the panel to see if it explains what each blink means.
A system that has a problem with the heating circuit will always bring the blower on and it will run continuously until someone turns it off.
Also check to see if there are safety high limit reset button on the unit that can be pressed to reset. Some manufacturers install them to alert you to a problem that needs to be corrected.
Mar 16, 2014 | Coleman Heating & Cooling
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
Home is not warm enough
This sounds like one of two issues. Either your fan speed is on high and needs to be adjusted to low, or if that is done then the issue lies in the duct work. either the duct work or plenum ( your air ducts connect to) is leaking air and the hot are is escaping threw holes. Another issue is rats or mice eating the duct work. Also check your thermostat to make sure that the fan switch is on auto and not on
Jan 10, 2010 | Heating & Cooling
No heat at night
You have a poor low voltage connection from the thermostat or a bad contactor.The contactor is the main relay control inside the condensing unit. The incoming voltage wires connect to it.
Contactors are inexpensive. I would change that first.
Check all your low voltage wires in the condensing unit for loose connections.
Dec 11, 2009 | Coleman Heating & Cooling
I have a Coleman/Evcon Presidential ser# 074878. The plumber says the Heat exchanger is cracked. Is this something I can fix myself or is it less expenxive to buy a new furnace?
The heat exchanger is a bear to change. depending on the age of the unit it might be more practical to replace the unit. However unless you trust this service tech I'd get a second opinion, because it is rare that a heat exchanger will crack, plus by law he or she should have shut the furnace down do to carbonminoxde. Especially rare in Coleman Evcon series units.
Oct 21, 2008 | Heating & Cooling
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
