Question about Refrigerators
Runs but not cold relay on freon tank clicks and clicks again after few seconds
    President:
  • 1,891 Answers
The freon tank is the compressor and the clicking you hear is the relay trying to start the unit . i don't know how old this unit is but it needs a new relay and it may work . there are hard start kits that can be installed also . called 3 in one and this replaces the relay and give's a kick start . ok for older units / if newer with run cap then i would use the org replacement part., hope this hepls mm
Posted on Feb 03, 2010
Fridge is getting cool but not cold and freezer isnt freezing and it has been re gased
Check the themostat. If you hear the compressor cutting out after running only a short while, that would be the problem. If the compressor runs constantly and the unit is not getting cold it is usually a gas problem, even though it has recently been re-gassed.
Jun 28, 2011 | Refrigerators
Starts only when it cold and does not start whwen hot
just off the top of my head. it may be the fuel pump relay, when its cold it is ok. but when hot it will not work. check it out. hope this helps. have a good day. if when hot. see if fuel pump is running, just get under car at tank in back. and have a person turn the key to on, while you put hand on tank to feel vibration. if pump works its not the relay. if it does not when hot,it is the relay! a fuel pump only turns on a few seconds to get fuel to engine, then when running it is on all the time.
Jan 19, 2011 | 1999 Land Rover Discovery
REFRIGERATOR NOT GETTING COLD
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. If the relay is ok there is a compressor problem or low freon it it don't start
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
May 30, 2010 | Refrigerators
It's not getting cold
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jan 20, 2010 | Kenmore Refrigerators
Kitchenaid Side by Side Refrigerator minus the cold air?
your compressor has issues. some times the start relay goes bad or the compressor windings are shot. thats why it clicks on then off .a service tech can install a "3-n-1 hard start on it. sometimes that works. good luck
Dec 10, 2009 | Washing Machines
I have a stand alone freezer model MFU17F3GW8 serial # WB11907298 my problem is that it does not get cold enough. what could be the problem?
Are the condenser coils on the back warm or room temp. should be warm
How to check stuff>
evaporator coils are behind the rear cover inside the freezer at the bottom.
Compressor or freon problem will require a repairman.
Oct 15, 2009 | Freezers
A/C blows hot on 1999 Chevy Cavalier
That could be the case. The other problem could be that you are losing freon for some reason. Find someone who can check the freon level for you to make sure that it is not leaking. The valve to fill the freon can get bent which allows for the gas to escape and then you run into this problem.
Jun 03, 2009 | 1999 Chevrolet Cavalier
No cold air. compressor works for seconds and shuts off
Replace the compressor, if it quits running after a few seconds, it is more than likely your compressor causing the problems
May 29, 2009 | 1992 Honda Accord
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
