Question about Dell Latitude D510 Notebook
Dell Inspiron 8600 laptop - StartUpProblem=UNMOUNTABLE_BOOT_VOLUM
Dell Inspiron 8600 laptop --- StartUp Problem = Blue Screen = UNMOUNTABLE_BOOT_VOLUME (even in SafeMode) "STOP: 0x000000ED, statusCode=0xC0000006 (means WHAT????)" ...MSDN's'BugCheck' says the StatusCode="The status code from the file system that describes why it failed to mount the volume" ..but no other 'hints' ****how do i find out what it means? ****
//**also, BlueScreen suggested "disabling BIOS memory options such as caching or shadowing"
...but can't find and way to do that via F12(BootMenu) or F2(SetUp) ***do you know how?***
// Tried: (at beginning of startUp) => F12 (BootMenu) // selected 'Diagnostics' // 'Pre-boot System Assessment' ______= Failed //
"Booting Dell Diagnostic Utility Partition-pressAnyKeyToContinue" // ...=>HardwareDiagnosticProgram // selected "SymptomTree" + "HardDriveErrors" ...=>DeviceSelfTest, result="ErrorCode: 0F00:013E, Msg: "IDE device failed: A possible failure is predicted by the drive's S.M.A.R.T. status. It is advisable to immediately back up! "the given erroe code and message can be used by Dell Technical Support to help diagnose the problem. - do you want to continue testing? // selected No + manually selected "ConfidenceTest" , result= "ErrorCode: 0F00:133E , Msg: (...same as SelfTest resultMsg)
***....looks like the hardDrive (HD) is 'toast'!!???*** ....where do i go from here???*** ...is there some 'magic' way of resurecting the HD???*** ....if not, is there any way of recovering (any?) of the files so they can be moved to a new HD???*** [no backUp position available!!]
Thanks for any light you can shed on this mess...
longggene
  • Dell Master
  • 12,061 Answers
OK simply your hard drive has failed... You need to get a new one, and install it, in the laptop after taking the old one out. Then you will have to install an Operating System. & Drivers all again. You could download all of that from the Net.
Posted on Feb 03, 2010
2 Suggested Answers
  • 157 Answers
SOURCE: Dell Inspiron 8600 laptop: StartUpProblem=UNMOUNTABLE_BOOT_VOLUME
If the hard drive is toast, you are out of luck. Seagate offers recovery services for bad hard drives, but there are no guarantees on a failed drive. Have you tried repairing the windows o/s. If you use the original Windows Release disc, it will examine the disc drive and find the current operating system, based on your input, it will attempt to repair the O/S without you loosing your data. YOU MUST BE CAREFUL TO SELECT THE CORRECT OPTIONS.
If the windows O/S CD has problems with your hard drive, then the next step would be to talk to seagate.
I have a blue screen that says "UNMOUNTABLE BOOT VOLUME" And system will not boot up any further?
This means that the hard disk drive has a problem. It could be an electronics failure or it could be a driver problem. Try to start the computer in SAFE mode by pressing the F8 at bootup. This will verify the hardware.
Jul 14, 2014 | Dell Inspiron B130 Notebook
Unmountable boot volumn error with lines on screen
this may help. just watch the video and folow the directions. good luck.
Apr 11, 2013 | Dell Inspiron 8600 Notebook
Dell xp will not boot and has lines across the screen
I would say your Graphics Adapter is gone. Have you removed the HDD and tested it? Has it been Cleaned? Fan? vents? Heatsink? Overheating? If the graphics adapter is gone it's a death sentence in a laptop. You can try replacing the Thermal Paste and cleaning the Laptop out. But it may be to late.
Apr 11, 2013 | Computers & Internet
How to remove the unmountable boot volume 1525 dell inspirion be cuz i have the blue screen, try go to the safe mode but freeze after it shows all the hard drive data its a stand still
if you can boot normally i suggest going to filehippo.com or cnet and download a free disk partioner and it will remove the boot volume for you. under run, msconfig, there is a boot option select the boot mount you want that may fix it let me know
Mar 15, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1300 will not go into safe mode. I am getting a blue screen with a message Stop (oX00000000ED) (oX82F99868) (oXc0000006) (ox000000) Unmountable - Boot - Volume. I have no idea what...
Best case is your os files corrupted, in that case you can try reinstalling your OS. If that does not work then there may be some hardware issue, it'll best if take it to support center.
Mar 14, 2011 | Dell Inspiron 1300 Notebook
Unmountable boot volumn happens on startup can not start in safe mode or reformat tried to run a test using the fn key
The hard drive hardware has failed. This drive is either dead due to a circuit board error, motor or spindle failure.
May 01, 2010 | Dell Inspiron 1000 Notebook
Blue Unmountable Error Screen
run MEMTEST, DOWNLOAD MEMTES, BURN IT ON BLANK CD OR DVD, RESTART YOUR LAPTOP WITH THIS CD IN, CHECK THE PROBLEM, MAKE SURE IT PASSES ALL THE STEPS, ALSO TRY TO INSTALL OS FROM ANOTHER CD...MAYBE THERE IS CORRUPTED FILE ON CD OR IT`S SCRATCHED OR SOMETHING, AFTER ALL THIS IF YOU STILL HAVE SAME ISSUE- 2 ND STEP IS REPLACING YOU HDD
Mar 08, 2010 | Dell Inspiron Mini 10 Notebook
Feb 03, 2010 | Dell Latitude D510 Notebook
Blue Screen
Likely a driver issue.
http://support.microsoft.com/kb/314063
Boot to the safe mode, run a system restore to before the problem, see if it is resolved. A lot of the time, issues like this are caused by a combination for old drivers and new windows updates.
Jun 23, 2008 | Dell Inspiron 8600 Notebook
Crash and Burn dell inspiron 8600 Help
Believe it or not, this sounds like a memory problem. Anytime you see an error of a page fault in a non-paged area, teh first thing to look for is memory issues. Can you move the memory stick(s) around? Try that first. Microsoft does not handle memory errors in certain areas very well. Sometimes moving the physical sticks around can place the bad memory cell into a less critical area that can be handled better.
Dan
Mar 25, 2008 | Dell Inspiron 8600 Notebook
Dell Latitude D510 Notebook Logo
393 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
