Question about Dell Office Equipment & Supplies
Dell All-in-one Printer 966 The wheel that holds the belt that the ink cartridge tray rides on popped out. Having trouble getting it back in.Help?
  • 542 Answers
Actually need to tighten the belt and also fix the catridge with the help of expert engineers or service center experts.
Revert back for more assistance.
Posted on Feb 03, 2010
  • Rajesh Pai
    Rajesh Pai Feb 10, 2010
    I have not received any update on the issue. If problem got resolved, Please give your valuable feedback/rating for the solution provided.
DELL AIO 966 Carrier belt detached from printer
The belt goes through the back of the ink carrier.
There is a spring somewhere that keeps tension on the belt with the white roller.
The belt itself hooks into the frame of the machine.
Jun 21, 2009 | Dell 966 All-In-One InkJet Printer
Dell Photo 966 Ink Cartridge Keeps Gumming up. Cleaning Cartridges doesn't help. Wipe cartridge off and maybe it works for one or two pages before quality goes down. Replaced cartridges but still have same...
Since you already replaced the cartridges there is a problem with the printer.The cartridge must have made the pinter bad.Now you have to take it to the Service Center.
Regards
Jun 18, 2009 | Dell 966 All-In-One InkJet Printer
The drive belt on the inkjet carriage came off it's wheels.
You'll have to disassemble the printer, remove the bottom of the printer and turn it upside down to where the belt and underside of the ink carriage (where ink comes out) is exposed. Take the closest loop of the belt and insert it around the plastic piece attached to the carriage [see image]. Then reassemble the printer. If you aren't good at taking things apart and re-assembling them you may have a hard time with this. Also, you may severely damage your printer if you break something mechanical or electronic in the process. Don't blame me.ff8bdfe.jpg
Mar 27, 2009 | Dell 966 All-In-One InkJet Printer
Refilled Ink Cartridge on Dell 966 all-in-one,how do i reset it?
I had this same printer but never was able to reset it. It has some type of sensor on it. That will not let it reset. I was told to unplug it from the computer. Turn the printer off. Reboot the system and plug the USB connector back into it once the system is booted. You may also try to reinstall the printer driver. I also find out that when the printer software says that the ink is low, it really is not. So keep on printing. What I eventually had to do is get a HP. No problem with HP, I can get a refill and it works. Now that I am think about this. See if you can disable the ink monitoring option in the software.
I hope this helps.
Please rate.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 966 doesn't recorgnise lexmark cartridges
I don't understand the printer message. Even though it may be "compatible" to a Lexmark, you may have to get the Dell cartridge because it will only recognize a Dell branded cartridge. At least try to reinstall the old one and see if you get the same message. If you do, then you may have a printer problem. If not, then the cartridge is the culprit.
Jan 24, 2009 | Dell 966 All-In-One InkJet Printer
Changing ink cartridge in dell photo 966
It's probably located under the scanning bed.
Look for another section break below the scanning bed.
Lift it up. The print cartridges should be inside.
Mar 25, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All in one printer
make sure sticker off ink as u put it in go download new drivers from dell.com for it they have big updates to fix that
Feb 21, 2008 | Dell 966 All-In-One InkJet Printer
Trouble installing ink cartridge
We've met several problem like this. Hope you can manage to look for the lock notch at the top of the ink tray, or it may be located beside of the tray holding the body of the ink cartridge. If you found out the lock notch is broken, you can revised by putting a piece of paper to tighten just enough to hold on the ink cartridge to pop-out.
Best regards,
Rosener Guyano
Dec 11, 2007 | HP Photosmart C3180 All-In-One InkJet...
77 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
