Question about Garmin nuvi 765T GPS Receiver
My Garmin nuvi 765t is directing me on local roads instead of highways, even though I selected ''shortest time'' in my preferences. I've owned other nuvis in the past, and never had this problem. Any idea how to re-program the nuvi 765t to default to highway driving?
********, I tryed different ways. Doesn't work. I had 2 GPS at the same time:nuvi 265 and nuvi 765t. On my way back from Ottawa Canada to New York the 265 showed route 1 hour less then nuvi 765t. (even thow I turned off truffic.
Posted on Jul 04, 2010
  • 12,061 Answers
Thats the problem it thinks the shortest route is the way it is doing it... switch mode back to normal. NOT shortest route.
Posted on Feb 03, 2010
How do I get my Garmin 1350 gps to take the highways not the back roads. Have tried it on "shortest distance" and "fastest" doesn't work either way
Setting the Avoidances to Enabled and checking off the box beside the Unpaved Roads should avoid most back roads unless the back roads are paved.
Setting the GPS Route Preference to the Faster Time will usually route via the highways unless it is actually faster to take the secondary roads.
In any case it is usually a good idea after creating the route to view the map and have familiarize yourself with the route. Via points can then be added to modify the route as necessary.
Sep 18, 2011 | Garmin Nuvi 1350/1350T 1300 1390 3790T...
How do I get me garmin 1350 to take the highways instead of the back roads.
You can tell it to take the shortest route, and this will go on all roads including backroads, or you can tell it to take the fastest route and it will include highways. I would highly suggest you leave it on 'fastest route' setting.
Sep 18, 2011 | Garmin nuvi 1350 Car GPS Receiver
How do i get my Garmin to only select national highways and toll roads instead of back roads?
go to Tools... Settings.... Map..... under Preference chose Faster.... under Avoidances make sure you have only the areas you want to AVOID checked.....
Dec 02, 2010 | Garmin nuvi 205 GPS Receiver
How do i program to take popular or main route instead of shortest back road cross country route ?
Go to Tools......Settings...... Navigation..... as your Route Preference chose Faster Time
under Avoidances make sure its Enabled and Highway is NOT checked to avoid
Nov 15, 2010 | Garmin nuvi 255W GPS Receiver
Bad directions
It sounds as though your avoidances is set for "Highways." From the main menu, press, "Tools" then "Settings" and then "Navigation." Press "Avoidances" and see if there is a check mark next to "Highways." If there is, press it. The check mark should disappear. Let me know if this helps.
Mar 09, 2010 | Garmin nuvi 255W GPS Receiver
Describe your How can I set my garmin nuvi 350 to
If you have set it to fastest, as opposed to shortest, it should take you on interstates for the most part.
Oct 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
Why does my garmin 350 send me on back roads instead of highways
settings are set at the shortest route, change to the quickest route....will put you back on the main roads
Feb 17, 2009 | Garmin GPS
Garmin Nuvi 350T
You might be choosing Shortest Route and that's exactly what it will do - find the shortest route, no matter what the quality of the roads. You should try choosing Fastest Route.
Jan 10, 2009 | Garmin Nuvi 350 Car GPS Receiver
We were sent over the worse mountain roads going from Lexington SC to Franklin NC. It most certainly was a dangerous way to go on windy mountain roads. The NUVI indicated it was the fastest way and the...
Welcome to FixYa:
I am not sure which model of the Nuvi you are using but I have the Nuvi 660 and can feel your pain. What use is going over a mountain or down roads made of gravel and miles from civilization only because it is technically a "shorter route"
So here are the basic directions to change that setting and get the Nuvi to keep you on the highways and interstates. If it varies too much, either respond with your model number or go to Garmin.com and get the manual for your model:
Go to SETTINGS
then NAVIGATION
click on ROUTE PREFERENCES
You should find what you need here, but to tell the Nuvi which type of roads to avoid and which ones to stick to:
go back to the SETTINGS menu
touch NAVIGATION again
and click on AVOIDANCES
Hope this helps and be sure to keep us updated!
TJ
Dec 13, 2008 | Garmin GPS
Shortest Route and Fastest Route Garmin Nuvi 200
The problem could be in your avoidance settings. I know when I was in Delaware, a 1/2 hour trip turned out to be a 3 hour detour because I had set to avoid highways.
In Garmin, if it's checked, it means AVOID. I know the documentation isn't clear but I've learned from experience (trial & error).
Sometimes it happens. Garmin isn't perfect but it beats looking at a map most of the time.
Jul 03, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 765T GPS Receiver Logo
281 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
