Question about Whirlpool WGD6400S Gas Dryer
How do i open the front cover on my dryer
I need to open the dryer i know that you have to lift the cover but it's locked and i cant open it
  • 572 Answers
Grab a putty knife clips are on the sides near the door. door needs to be opened
Posted on Feb 05, 2010
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Jan 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
Tip
Maytag Square-Front (1998) and Sloped-Front (1999) Dryers Front Panel and Top...
Most of the internal components of Maytag Square-Front (1998) and Sloped-Front (1999) Dryers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip. Open the door then lift the front of the top cover and tilt it toward the rear of the dryer.
The internal components of the dryer can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Neptune Front-Load Washers. The only difference is the dispenser bezel removal.
on Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
One of the "fins" inside the dryer is coming off and just needs to be tightened but I cant figure out how to get to the drum to tighten the screw.
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffles securing screws can now be re-tightened. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Sep 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the top? the padals inside the drum are coming loose
The front panel needs to be removed first before the top cover can be lifted to the rear of the dryer to access the outside of the drum and re-tighten the screws attaching the baffles to the drum. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Aug 01, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The agitators in the drum are loose and I need to know how to get to them to tighten?
Those are the drum baffles and the top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Jun 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
Sounds like change is trapped in dryer makes a rattling noise? possibly trapped in one of the three rotating bars in the dryer drum. how can we get this out?
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and the screws securing the baffles. But before that, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Jun 13, 2010 | Maytag Neptune MDE7500AY Electric Dryer
Removing top of dryer to get to the drum
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum. But before that, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
May 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
We just had some sort power surge, directtv rebooted and dryer stopped. we checked all curcuit brakers and everything ok. dryer will not start. purchased in 2003. thanks
This has probaly blown the thermal fuse. It is not resettable you will need to check it for continuity. The part # AP4048636 and the link. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru diagnosing and testing this.
Mar 26, 2010 | Maytag MDE308DAYW Electric Dryer
I can't get the top off my Maytag performa MD2300 dryer. I used the putty knife idea but the clip won't budge. I'm pushing straight in from the front, cheating a little up, then down. It's like hitting a...
The top cover is held by two hold down brackets hidden behind the front panel posts. Lifting of the top cover requires the removal of the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening and securing the front panel to the front shroud assembly.
The front panel is held to the cabinet by clips on each side secured to the cabinet front flange. Small slots in each side of the front panel engage the clips and hold the front panel in place. Grasp the sides of the front panel near the top cover then pull the front panel away from the cabinet.
Tilt the top of the front panel away from the cabinet and lift it up to release it from the two clips retaining its bottom to the base of the dryer, and then move the panel away.
Locate and remove the 5/16" hex-head screw attaching each hold down bracket to the cabinet. Swing each bracket to the outside then unhook it from the slot in the lip of the top cover. Lift the front of the top cover and flip it to the rear of the dryer.
Reassemble the front panel and the top cover by reversing the given disassembly steps.
Mar 25, 2010 | Dryers
Whirlpool WGD6400S Gas Dryer Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
