Question about Sony BRAVIA KDL-46V3000 Television
My Sony Bravia KDL-40S3000 started turning on and off by itself for no reason.
  • 148 Answers
Hi there..first off PUT A FAN AS CLOSE TO THE TV AS POSSIBLE...Your units powerboard is overheating..the fan will slow this down big time(once the tv goes all the way out you have a useless tv till it gets repaired!), I have a Poloroid 32" lcd on "life-support" it was doing the same thing when I bought it cheap ( I buy them and fix them), I put a box fan on low behind it and it has not shut off on its own for 3 weeks now....Now to explain how to diagnose and fix this problem............
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this helped you (or not )please rate, thank you!
Posted on Feb 03, 2010
  • roadtrippin Feb 03, 2010
    Hit here , I finally figured out how to post my detailed pictures of broken capacitors...I know these will help...good luck again..and don't forget to vote , thank you again!
Where can I get a table top stand for sony kdl-40s3000
Try sony directly or GOOGLE the model and item wanted.
Nov 04, 2012 | Sony KDL-40S3000 40 in. LCD HDTV
I can't get my Sony kdl 40s3000 out of standby mode
You can look to see if power light blinks in a sequence which would be a error code but unless you are prepared to take it apart and know what to look for best left to a tech or a shop..
Sep 06, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound on my Sony Bravia KDL-40S3000
Check whether you can hear the sound through headphone, if the TV has a headphone socket. If it has, there are some internal defects.
Aug 12, 2012 | Televison & Video
Turn on tv on sound on my sony kdl-40s3000 can anyone give me a suggestion
cant get what you mean kindly repost and explain your tv problem in detail.
Mar 01, 2010 | Sony KDL-40S3000 40 in. LCD HDTV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
How to change from ntsc to pal on bravia kdl-40s3000 40 "
Changing this requires a change of the tuner. There is nothing inside the set that can make this change. There are external systems that can do this, but they are expensive (multiple $100s).
Bottom line is that this would require a change in the internals of the set.
Hope this helps.
Dan
Mar 16, 2009 | Sony KDL-40S3000 40 in. LCD HDTV
Sony Bravia turns off by itself
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
Jan 08, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Green pixel lines
It sounds like a bad LCD panel but you would have to post a picture of the problem for me to be sure
Sep 11, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA  KDL-46V3000 Television Logo
354 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
