Question about Dell Dimension C521 PC Desktop
I have at current a AMD sempron 3400+1.80GHz processor,socket AM2(940)core VID 1.100V,core speed 1002.2 MHz,bus speed 200.4MHz,HT link 801.7 MHz,stepping 2,L1 data and inst 64 KBytes-2-way,level 2 256 KBytes 16 way but want i need to know is what processor would you suggest for greater speed to suit this dell dimmesion c521 system,many thanks,garnedd.
  • 30 Answers
The main thing is before you go swapping cpu there are some things to consider. 1. the new processor may draw more power than your current power supply can push out. 2. it will probably generate a lot more heat...both are bad..
But if you insist you can get away with an Athlon 64 X2 5600 or 6000+ cpu be careful though because some have different voltages which may not work with your board.
hope that helps.
Posted on Feb 03, 2010
Testimonial: "thanks very much for your warning's and the processors you have mentioned and shall look into the voltage equaztion with the motherboard,many thanks"
Processor upgrade
WHERE IS THE QUESTION.
Feb 24, 2015 | Max Computers & Internet
I want know intel d 945gcr supports quied core processor or core 2 duo processor?
Support for the following:
Intel Core 2 Duo processor in an LGA775 socket with a 800 MHz system bus
Intel Pentium D processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Pentium 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Celeron D processor in an LGA775 socket with a 533 MHz system bus
Aug 14, 2014 | Computers & Internet
Can processor AMD Phenom X4 9650 Quadcore to use motherboard Asus M4A78T-E ?
you cannot use m4a78t-e to amd phenom x4 9650 because it does not support am2+ socket, it only support am3,phenom II,sempron 100, and athlon II processor.
Aug 18, 2011 | AMD 2.3GHz Phenom X4 Quad-Core 9650 AM2+...
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
How do i read the motherboard to see what board i have
The Manufacturer of the mother board is MSI and details are as follows:
Manufacturer Part # :K9MM-V
Product Type :Motherboard
Form Factor/chase: Micro ATX
Chipset Type :VIA UniChrome Pro K8M800 / VIA VT8237R Plus
Multi Core Support :Dual Core
Max Bus Speed :800 MHz
Socket Type 0 ( 1 ) :- Socket AM2
Compatible Processors : Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
It supports 64 Bit Processor
Multi Core Support :Dual-Core
Its Supports RAM Technology: DDR II SDRAM
RAM Installation : 0 MB / 2 GB (max)
Supported RAM Speed :PC2-4300, PC2-6400, PC2-5300
RAM Features :Two DDR Channels
Video Memory :Shared video memory (UMA)
Audio Codec :Realtek ALC655
Sound Output Mode : 5.1 channel surround
Expansion Slots Total (Free) :1 processor - Socket AM2
You can addin RAM of :2 memory ( 1.8 V ) - DIMM 240-pin
PCI :3 PCI ( 3.3 V/ 5 V )
Storage Interfaces
Additional Connectors : 4 x Hi-Speed USB
Dec 21, 2009 | MSI K9MM-V Motherboard
Bus Speed 200mhz instead 1000mhz
PLEASE INDICATE WHAT IS YOUR PROBLEM....
Jan 08, 2009 | ASUS M2N-E Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
amd 3200 + anthlon ok with fsb 266 mhz soket a
Jan 10, 2008 | ASUS A7S333 Motherboard
PROCESSOR
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
I have put a sempron 3.4 processor in but the system only recognises it as 2ghz ?
Your processor speed is actually correct AMD calculate the clock speeds differently from Pentium type processors, a 3400+ is a 2.0 GHZ processor, see the list below for speeds Sempron 2500+ 1.40 GHz 800 MHz 128 KB 754 Sempron 2600+ 1.60 GHz 800 MHz 128 KB 754 Sempron 2800+ 1.60 GHz 800 MHz 256 KB 754 Sempron 3000+ 1.80GHz 800 MHz 128 KB 754 Sempron 3100+ 1.80 GHz 800 MHz 256 KB 754 Sempron 3300+ 2 GHz 800 MHz 256 KB 754 Sempron 3400+ 2 GHz 800 MHz 256 KB 754 Don't worry too much about the proceesor not being recognised as long as you know it is running at the correct speed.
Nov 12, 2006 | Iwill ZPC-SP (ZPCSP) Barebone
Dell Dimension C521 PC Desktop Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
