Question about Canon Rebel XT / EOS 350D Digital Camera
Err 05 When I attempt to take a picture on my Canon EOS Digital Rebel, it won't allow me to take the photo.  Instead, it shows a Err 05 message.  I cannot locate my manual and can't figure out what the Err 05 means. Help?!!!
  • 1 more comment
  • mobrienlawye Oct 24, 2008
    I have the same problem, but have turned it off and on over and over and it still won't pop up. Can't figure for the life of me what's obstructing the flash?
  • Anonymous Jan 20, 2009
    Had the same prob.  Err 05 message.  Managed to get the flash to pop up and then wiggled the silver latch.
    All good now and no error message
  • Jocelyn Jan 15, 2012
    To the one that said "I have the same prob."
    I made my flash to pop up. and it flashes and everything, but what sucks that I have to pull it up, usually it goes up by itself right? Which I don't really want to do.
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Posted on Jan 10, 2009
Err 05 is "something obstructed the built-in flash's automatic pop-up operation. Turn the power switch to <OFF> and <ON> again*." (Presumably after you remove whatever is obstructing the built-in flash.
* according to canon Digital rebel instruction manual.
Posted on Feb 23, 2008
  • lucky samson Nov 09, 2011
    what if it's clear
Canon Rebel XT Err 05
Hi. Take a look at the below link, it may be your solution.
Canon Rebel xsi Err 05
Feb 21, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 1000D SLR will turn on but has a "busy" message when looking through view finder. Will not take a photo.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Feb 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
The menu screen not working. Also, when i try to take photo it showing (busy). what shall i do???
I hope that helps.
Jan 07, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Camera has no display, appears to be locked up, shows busy through veiw finder, otherwise focus ok but no picture taken. Battery and SD card ok.
I hope that helps.
Nov 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 followed by the "Busy" issue in the viewfinder
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
"BUSY" Problem
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
ERR 01
Try remove the lens, it may be faulty.
Apr 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel EOS camera
Err 99 is a general error msg. That is, it has to be connected to the service soft that only Canon self or an ASF has, to know more precisely the problem.
To narrow the possibilities;
-choose Av, shutter priority,
-choose the smallest aperture your lens allows, 22 or 29 or so,
-while pressing and releasing the depth-of-field preview button, (front, under the lens release) look into the lens from the front.
If the diaphragm doesn't move it has to be changed. If you have the 17-55 standard lens; throw it away and buy a better one instead of paying a repair. You'd be better off.
If you have the Err msg with several different lenses the problem is in the body itself, often the shutter. Check also your PINs in the CF-slot. If one PIN is toching another; break off the bent one and normally you can go on, the PINs are almost all doubled.
Jul 27, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
3,038 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
