Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
TURNED TV ON AND HEARD A CRACKLE AND IT TURNED OFF AND THE POWER LIGHT FLASHES 5 TIMES THEN STOPS AND REPEATS.
  • Panasonic Master
  • 8,457 Answers
Power board is dead.Replaced it with a refurbish power supply,buy at Shopjimmy.com,or Ebay.com.Know how to solders?Check all the capacitors that puff up or burst open might get power back.Because something else might also might burn don't know about or the ability to find out.
Posted on Feb 03, 2010
  • Chi Chu Feb 03, 2010
    Replacing capacitors not garentee will get power back.
Green power light flashes 3 times then repeats
The defect is likely a sensitive component to over voltage (lightning) on the main power supply. But you should not exclude other boards too, since ohter board also have local power supplies and sensitive CMOS integrated circuits. Check all MOSFET transistors on the the main power supply, since they are the most sensitives. Also the regulator IC to control the PWM sent to the MOSFET is made of CMOS (sensitive). Then check all the diodes even if they are more robust to lightning. There is a MOV that absorb the lightning that could be shorted but in your case it seems to have survived.
Sep 21, 2017 | Toshiba 55ZV650U 55 in. LCD HDTV
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
Jan 21, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
Video
How many times does the light flash?
Sep 28, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Repeating 5 flash red on power light, no power up
When the red light blinks five times that would indicate that there is a problem with the "Lamp Driver". That would be Sony part 1468798-14 for a Sony KDF-41WE655.
Aug 07, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Timer / Stand by light flashes
could be high voltage problem. time for your local repair shop.
May 27, 2006 | Sony KP-53HS10 TV
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
