Question about iLO 2600 Television
Hooking up dvd
I misplaced the remote to my ilo tv, how can I hook in a dvd?
  • 123 Answers
If you plug in a scart from the dvd to your tv, when you switch the dvd on your tv should switch automatically, if not, play about with the differant scart connectors
Posted on Feb 19, 2008
My ilo tv wont hook up to my playstation on any channels.
Try plugging into the Component Two jacks (down along the left side). I couldn't figure out mine either, so was resorting to unplugging and plugging in the game when I wanted to play. I had the DVD in those jacks originally. Now the TV is stuck, not responding to either the remote or it's own buttons (except off and on), so we are switching 3 different types of entertainment in the same jacks. It'll work for the time being.
Dec 02, 2008 | iLO 2600 Television
We need a new remote for our ilo TV in order to hook up a DVD-VCR player!
First off you will need a remote that has the ability to operate your ILO TV. www.remotes.com has a replacement that will work for you. As you will need to access the inputs for your TV to receive the signal from your Philips unit
Oct 10, 2008 | iLO 2600 Television
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
My Ilo tv
You cannot program a Direct TV remote for an Ilo.
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Ilo Television
check to see if your wires are not broken.but let me say to you that dvd does not work with channel 3 or 4 on a tv they work with av connection you can activate that from off your remote.try your dvd on another tv if it works then you will have to take tv to a tech for repairs.if it does not work then your problem is your dvd which will needs to be repair.goodluck.
Mar 23, 2007 | iLO V27DMBX Television
Televison & Video Logo
43 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
