Question about Samsung SL202 Digital Camera
Samsung sl202 trouble!
I have a sl202 and when i try to turn it on, the lent comes out, and right after that goes backwards again, a beep sounds, and it turn itself off. i got it this christmas, if my dad finds out he is going to kill me
  • nrc09 Feb 03, 2010
    only the last one worked, forcing the lens to stay out, I taked it to the beach and i always carry it on its case, could be any of the problems you said! thank you a lot!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 03, 2010
Testimonial: "Thank you! Your advices were very helpful!"
  • sueczan Nov 10, 2010
    my sl202.a few years old was doing the on off beep syndrome...I tried the holding of the lens .ideas1-4 ..nothing.,did no.6 nada ...then decided to try to clean lens barrel while open and this time it worked!!.must've had a grain of dirt in there somewhere...or alignment..but for now it's working so don't despair...keep trying!
Tip
Samsung SL202 Flashing Yellow Light Is your Samsung SL202 flashing a yellow...
Is your Samsung SL202 flashing a yellow light and not charging its battery?
This is an indication that your camera has decided it needs to completely discharge its battery before the charge cycle begins it again.
Rechargeable batteries last longer and perform better when they are completely discharged before being recharged. This is normal.
I hope that helps.
______________________________
SL202 User Manual here.
SL202 QuickStart Manual here.
on Apr 18, 2010 | Samsung SL202 Digital Camera
My samsung pl100 wont turn on. the lens is extended and its fully charged the green light comes on then beeps and shuts off. This camera is brand new ive only had it 1 week! how do i fix it?
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Dec 23, 2010 | Samsung SL202 Digital Camera
It the lens slides out half way and makes a beep noise and goes back in
Hello
The lens gears might be damaged or out of calibration need to be handled by Samsung support nearest you or claim the warranty if it has.
Some time the low battery gives the same problem
Good Luck, and do rate the solution if helped
Dec 22, 2010 | Samsung SL202 Digital Camera
My Samsung SL202 is making a loud beep when i try to turn it on. The lens is out and will not retract. The camera immediately shuts off when turned on and the screen is blank.
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Dec 16, 2010 | Samsung SL202 Digital Camera
My Samsung SL202 isnt working the back screen stays black when i try to turn it on and it makes a sizzling noise then then lens comes out but dosent pop back in
that is a lens error in the alignement of the lens;
its may due to some dust in motor lens block ***'y and probly needs to be clean ...
hope that will help
regards Alan..
May 14, 2010 | Samsung SL202 Digital Camera
How do you fix a stuck lens on a Samsung SL202 digital camera?
Yes I have tried Fix#7. I tried to push the lens as I turned on the power but no luck. I tried to twist the lens and turned on the power but still no luck but this time i tried to pull the lens and power on and the lens goes out. I turned off the camera and the lens return to its place as it should.
Thanks for the tip...
Randy
Oct 17, 2009 | Samsung SL202 Digital Camera
Open Questions:
See all Samsung SL202 Digital Camera Questions
Samsung SL202 Digital Camera Logo
1,183 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
