Question about Whirlpool 24 in. GU940SCG Built-in Dishwasher
Whirlpool GU940SCGBO won't start. has power and
Whirlpool GU940SCGBO won't start. has power and sounds like it wants to start but won't
  • 254 Answers
Possibly a internal fuse,, or ur pump motor assembly has failed or your control board or user interface arent comunicating,,, so either it could be an eectronics problem or the pump motor is defective,, most had a 5yr parts warranty on that pump motor...
Posted on Feb 03, 2010
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
Wtw5550x whirlpool it not working probably ran auto and manual test mode it ok some cycle worked the next one it won start Sound noise lic bloc flash what should I do
Whirlpool Cabrio WTW5550X Problems: Not agitating, kind ...
www.fixya.com/.../t14828796-whirlpool_cabrio_wtw5550x_problems_...
Oct 31, 2012 - Posted on Nov 01, 2012.
Whirlpool Cabrio Automatic Diagnostic Mode - YouTube
? 2:56
https://www.youtube.com/watch?v=ObQSoeoaeCY
Jun 4, 2012 - Uploaded by RenewAppliance
This video will show you how to put your Whirlpool Cabrio in automatic ... my whirpool fills ok but wont wash or spin what is theproblem ??.
Nov 19, 2015 | Whirlpool Washing Machines
When I turn the dryer on and push the start button it won't start but it sounds like it's getting power
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2011 | Whirlpool Inglis IP8200 Dryer
My Whirlpool dishwasher won't drain and won't start, it makes a slight buzzing sound then clicks off...
While this could be a number of problems, I'll start by asking how old is the unit?
Jul 09, 2011 | Whirlpool Dishwashers
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
The unit is a duet dryer ser#wed9200sqo unit will not heat up
my whirlpool dryer duet model wed9200sqo, everything comes on but when i push the start but it just makes a sound like like it want to start but won't, would i need to put a new start switch in it?
Mar 18, 2010 | Whirlpool WED9200SQ Electric Dryer
Whirlpool 24 in. GU940SCG Built-in Dishwasher Logo
201 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
