Question about Olevia LT42HVi 42 in. LCD Television
LT42HVi problem my set flashes blue on and off. It does nothing else. I turn it on by the power button. Any comments? Samuel_h_11201@yahoo.com
  • 2 more comments
  • samuelh Feb 27, 2008
    actually this is not just the regular loss of picture "blue screen". You do not have any control nor do you have any character generation on the screen.
    thanks anyway.
    P.s. the company's service department said that the problem is the main board which cost 368.00.
  • samuelh Feb 28, 2008
    Benimur I agree whole heartedly and will persue a local guy. Once again thanks.
  • zachgj Aug 23, 2008
    TV set flashes blue on and off. It does nothing else. Have to turn it on by the power button.
  • jeffjohnson1 Nov 10, 2008
    same problem after some really wierd issues of color, sound, and generally tv having a mind of its own.  where can I get one of these boards?  is it worth the 370 plus shipping or will this just happen again in another year?  If so, might be better to put money in a new TV?  I hate to waste the resources and not fix this one, but also don't want to do something foolish.  I sounds as if this is a common problem with this model/brand.  Is it likely to happen again with the new board?  Design flaw???
    JJ
    Brigadier General:
  • 6,966 Answers
A blue screen is indicative of a "Video Mute" condition. This is triggered in the absence of a signal coming into the TV. Try to check your signal source which could be:
1. aerial antenna - might need reorienting;
2. cable - loose connection or perhaps you can call the attention of your cable provider;
3. external such as DVD or VCR - try to check for any loose or defective yellow RCA cable. In some instances, the DVD or VCR might not be reading the medium (disc or tape) and would require cleaning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 25, 2008
  • Louie  Role
    Louie Role Feb 28, 2008
    Hi again,
    I understand and appreciate the update/information.
    Most in-house and/or official Service Centers would opt for board replacement rather than component level repair to cut turn around or the time required to repair hence the 368.00 quote.
    Most of us working independently could go either way and I would suggest your friendly neighborhood service shop or a qualified professional willing to do component level diagnosis and repair. Cost might not be that high but repair time might be a tad longer.
    Cheers.
  • Louie  Role
    Your welcome and glad to be of some help.
Flashing blue screen
The main power regulator voltage outputs should be checked. Check this link for details about flickering.
Mar 31, 2013 | Olevia LT42HVi 42 in. LCD Television
My olevia 42 in power doesnot come on. blue light was on when I pushed power to turn on tv. Blue light went out but tv did not come on. Blue light didn't not come back on. Television was working good. I...
You may be aware that Olevia is bankrupt and apparently Emerson bought the leftovers and is offering service but no parts sales.
I found this thread discussing antoher model's various problems but I believe your power supply has likely failed.
Olevia thread
If it is the type of failure related to the switched-mode power supply, these can be repaired by a properly equipped tech; I've done hundreds of them while still in business (which I am no longer).
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
My em228 flashes blue red why?
It is NOT the battery. When you turned the bluetooth on, only hold the power button until the blue light flashes about 3 times. If blue tooth is enabled on your phone, this should allow the bluetooth to connect without having to search for any devices, that is, if you already have it in your settings.
The red and blue alternating lights are to setup the bluetooth and allow it to connect to your phone, THE FIRST TIME. Once the device is listed in the bluetooth settings on the phone, you can just connect, instead of searching for the device every time you need to turn it on.
Only hold the button until the bluetooth flashes BLUE, about 3 flashes........see if this works better for you.....
Another frustration, (sometimes) depends on what brand of phone you have. I know my EM227 connects differently between my DG Razr and my Samsung Eternity.
Let me know if this helps, and if not, let me know what phone you have, and I will tell you for sure, exactly how to turn on and connect, with no problems.
Good luck~~!
mstipps@yahoo.com
Nov 18, 2010 | Emerson EM227 Bluetooth Headset
Flat screen tv, power works but it shows a continuous blue screen
Yes,Ur Main Tuner signal board is dead.Replaced this Tuner signal board will solved this problems.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Siginal board for the replacement.
Mar 17, 2010 | Olevia LT42HVi 42 in. LCD Television
My Olevia won't turn on
Tries Ebay.com Shopjimmy.com for possible Tuner signal board.
Jan 29, 2010 | Olevia LT42HVi 42 in. LCD Television
The blue power button is on but there is no picture??
The blue power button goes on when the screen is OFF. It just tells you that the unit is receiving power. It goes off when you turn the tv on.
Jun 30, 2009 | Olevia LT42HVi 42 in. LCD Television
System won't power up
ITS BROKE - YOU HAVE TO GET IT FIXED OR THROW IT OUT. SAME THING HAPPENED TO US -UNDER WARRANTY BUT WE HAVE TO PAY THE $80 TO SHIP IT TO THEM. WHAT A FARSE.
Aug 04, 2008 | Olevia LT42HVi 42 in. LCD Television
No sound or picture
Keith, Check fuses Then Resoder The COMPLETE board I bet there is heat related problem W/Old Soder Just a Hunch!!!!!!!! G'Luck Chance One 559 @ Yahoo . Com
Oct 24, 2006 | Toshiba TP55G60 55" Rear Projection...
Olevia LT42HVi 42 in. LCD Television Logo
146 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
