Question about HP Officejet 4355 All-In-One InkJet Printer
HP Officejet 4355 All-in-One.Cartridge error.installation of new black hp 27 cartridge returns error message of wrong cartridge type for machine.generic new cartridge gave same result.tricolour 22 produces an unspecified error message.generics have been used previously in this machine.what is the poblem an how can i fix this?elderly pensioner uses it for medical reasons.
  • Manypets Feb 03, 2010
    Thankyou Muktar,your response was quite detailed an easy to follow,very much appreciated for your time.Top rated.But perhaps i should have put a bit more detail in.This printer was orginally on my neighbours computer.Recently i lent him a computer of mine running xp sp3.The cartridge errors were showing up on his computer ,same as on reloading printer onto my computer.I had read manual an used as advised,distilled water an a coffee filter (flint free)to very gently clean copper area on cartridge.reloaded,still same error message.Had tried all up a genuine HP 27 new an a generic to HP 27.What about a partial reset?Had read somewhere about turning off printer,holding both hash an 3 together while turning on machine.Anything else i can try to sort this out?
    President:
  • HP Master
  • 2,017 Answers
Check to see if the installed cartridge is the correct one for the printer. if the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Have a nice day and do not forget to rate please...!
Posted on Feb 03, 2010
I keep getting a msg saying carterage error on my printer
If you DID NOT use a HP cartridge you get the error message.
If you did use a HP cartridge. Unplug the printer. Wait 2 minutes.
Plug in the printer. If same error message. Remove cartridge and reinstall. Make sure no clear tape is left on cartridge contact face.
Jul 11, 2012 | HP Officejet 4355 All-In-One InkJet...
The printer is showing a message catridge error - Refer to device documentation to troubleshoot.
This is an internal electrical malfunction within the cartridge - I suggest you run the following two service tests:
1) You can 'temporarily' bypass an 'Incompatible Cartridge' error (or any other cartridge electrical malfunction error for that matter) by accessing the OJ's service menu...see the Inkjet411.com support youtube video found here:
HP Officejet J4500 J4600 4500 Cartridge Error Bypass -- HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
2) You can also run the 'tap 41' diagnostics check on the HP 901 cartridge(s) electrical health, via the access code/procedure shown in the following video:
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics -HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
Jan 17, 2011 | HP Officejet 4355 All-In-One InkJet...
CARTRIDGE FOR 5610V
Black Cartridge HP 27
Color cartridge HP 22
Photo cartridge HP 58
Jan 27, 2010 | HP OfficeJet t45 All-In-One InkJet Printer
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
My hp officejet j4580 says incompatible black ink cartridge
I've been in print cartridge hell since I bought a J4580.
I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
  • Make sure your print cartridges are installed.
  • Unplug the machine, wait 20 seconds
  • Press and hold the # and 3 keys
  • Plug the machine back in
  • You'll see a reset message on the machine, release the # and 3 keys
  • Follow the prompts to set the language and location
Cross your fingers, hopefully your printer will print now!
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
Hp 4355 cartridge error
Mar 10, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
876 people viewed this question
Seeker5211
Seeker5211
