Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
I have a Carrier Infinity 96 gas furnace with no heat
I have a Carrier Infinity 96 gas furnace in my (new to me) home. It has been working perfectly up until tonight. The fan is blowing but the air is cool. Any idea what would cause the sudden lost of heat? There is a glass circle cover behind the cover door were I see a green ligt and a blinking yellow light. DOes this mean anything to anyone out there?
  • 407 Answers
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Posted on Feb 03, 2010
Testimonial: "Great Solution. I spoke with the installer of the unit this morning and went through everyting you mentioned. It was as simple as a loose connection."
Carrier infinity furnace 2010 has stuck inducer pressure switch, Can I manually bypass and heat the house until serviceman arrives tomorrow?
I wouldn't bypass any safeties when its part of the exhaust system of the furnace. That is the first safety that acts in the furnaces sequence of operation. The induced draft will initiate and that pressure switch will close, proving the IDM is working and flue is clear. It's primary purpose is to exhaust any fuel that may linger inside the heat exchanger and then to reject the post combustion process. Carbon monoxide becomes an issue. As far as the Infinity, these units will not start if safeties are bypassed. The unit checks all safeties/circuits for continuity, and if a switch is closed when its not supposed to be, it won't allow.
Mar 05, 2017 | Carrier Heating & Cooling
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
Carrier infinity 80 won't heat
does your burner flame up and then go put two or three times if so
all you have to do is take out the burner and clean all the soot out of it and then wipe off the sensor
Oct 09, 2012 | Carrier Infinity Series Variable Speed...
We have a Carrier Infinity 96 furnace in our home, which was installed brand new in our house we built 5 years ago and this thing is a nightmare. We've had the code blinking away and and the technician in...
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST DIGIT DETERMINED BY THE
NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY THE NUMBER OF LONG FLASHES.
43 LOW-HEAT PRESSURE SWITCH OPEN WHILE MEDIUM-HEAT PRESSURE SWITCH IS CLOSED - Check for:
- Low inlet gas pressure (if LGPS used).
- Plugged condensate drain.
- Improper pressure switch wiring.
- Water in vent piping, possible sagging pipe.
- Stuck open low-heat pressure switch.
- Disconnected or obstructed pressure tubing.
Mar 28, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
Carrier Furnace infinity 96.model 58MVP060-F-18114. Furnace heats
Sounds like it could be your fan limit switch. Part costs about 20 bucks and is fairly simple to replace. This limit switch is a safety that prevents your furnace from over heating. Usually when your t/s is satisfied the blower runs for a little longer after the burners have stopped, and the reason for that is the limit switch. The blower is supposed to cool this limit switch to a certain temp. and once it reaches this temp it shuts the blower off. Yours is stuck:(
Feb 13, 2010 | Heating & Cooling
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Control suplimental system with carrier infinty system
Not really unless it is 24v control on the new stuff. However it is you can use the voltage from white (or W) at the tstat. You will be using the power supply of the carrier furnace. install a 3 amp fuse. and be prepare to replace the fuse in furnace while testing . The most you can get on those transformers is about 10 mpers @ 24v.
Mar 23, 2009 | Heating & Cooling
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
2,589 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
