Question about Audiovox VE-920 9 in. TV/DVD Combo
AudiovoxVE926 no picture
2 transistor and 1 condenser burned on smallest pcb inside flat panel,
part n. for transistor DF S2N. can I find this parts or equivalent,?.
  • Robert Rattew Feb 28, 2008
    No back light on lcd screen
    .1 mf 63v capacitor & 2 transistors part # DF S2N are shorted on small board # CL-70MA Looking to find where to purchase either the board or bad parts
  • vikshah Jun 22, 2008
    Have the same problem with PCB CL-70MA 060125. Has anyone discovered if a replacement is available. Has anyone found a schematic of the board to rebuild?
Have the same problem with PCB COMMAX CL-70MA 060125. Has anyone discovered if this board can be purchased? Does anyone have a schematic of the board?
Posted on Jun 22, 2008
Wont turn on single red light and then burns out
it can be the power pcb, a big thing with a transformer or just a heatsiked transistor(regulator) + a big capacitor,ussually blue or broun,check that capacitor and maybe other things on the power pcb
Nov 06, 2013 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
14" picture tube TV, when
hi;
there's a failure in power supply section. maybe H-out transistor inside or regulator has fail or burn out. this needs a TV technician to repair the problem.Not just like an LCD monitor that has block by block sections, CRT has many small parts to test and has to remove by desoldering its pins.
and dangerous because its has a HIGH VOLTAGE in the tube.
thanks.................
Sep 11, 2011 | Hitachi Televison & Video
Picture keeps going of sound stays on.i have switch of and on to get picture back
Hello, i have some method you may try.
1. Turn on your TV set, than wait whail untill picture off.
2. After picture off, try to knocking TFT panel smoothly. If you see flashing light from panel, its mean the backlight panel switched off.
Backlight panel consist of inverter board and ccfl inside the panel. If one of ccfl's burn out, all ccfl's will switched off by inverter board. make sure that the problem comes from one of these part.
Replace it.
I hope that will solve your problem.
Thanks.
Mar 10, 2011 | Samsung Televison & Video
Suddenly lost picture, sound is still working. The TV is 3 1/2 years old. Any fix for this? Parts?
If you are lucky it may be asimple power supply problem, with dry electrolytic capacitors. If you can find one or more capacitors with domed tops instead of flat tops, then it is an obvious sign that the capacitors require replacing.
Feb 25, 2011 | LG 42PC5DC 42 in. Plasma HDTV
Hello i have incubator brand suro 20 com king its running but there is no heating a parts burn inside the main controler i like to ask if you can supplied me with the schematic diagram to find the suitable...
I have a king surro with a temperature control fault 2 resistors next to power transistor on pcb burnt out I can tell values of any other components on pcb but does anyone have a controller board who can tell me what value resistors are steve-- protodezine@gmail.com
Jan 06, 2011 | Heating & Cooling
I need sceaic diagram for sony KV-29MF8. The horizonl outot is always getig shorted?
CAuses and soultion:
1) Duplicate H Out transistor
2) Check whether the H Out is a DF or AF. If it is a DF (With diode inside) an AF wont work
3) Disconnect the H Out and connect a 100 W bulb on the collector and ground. The multimeter reading should not exceed 120V. If it is more then check powersupply components especially the transistors and diodes.
4) If the power supply voltage is fine then the problem exists with the horizontal output section. Check the yoke for short ckt or the EHT transformer.
Dec 22, 2010 | Televison & Video
Lg flat 21 inch tv -horizontal o/p transistor burn after 1 minute & sound chik chik
You have to check the high voltage diodes near the horizontal transistor and the small transformer. Diodes might have gone leaky. Check the capacitors also.Replace the black colored diodes with new ones with identical part no.
Rarely EHT coil will have problem.
Sep 15, 2010 | Televison & Video
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
How to find pins for the EHT and FBT.
Franko, If your sure about troubleshooting HI VOLTAGE then disconnect the horizontal output transistor first. Is it shorted? if it is get the fly and the transistor. But I wouldnt start it up with out a variac transformer. For the parts, go to http://www.partstore.com amd see what the parts cost or get the tele # and call them. BE CAREFULL. Good Luck
Jun 30, 2006 | Sony KV-27S20 27" TV
Audiovox VE-920 9 in. TV/DVD Combo Logo
349 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
