Question about Kenmore 46462 Front Load Washer
How do you repair drum bearings - Kenmore 46462 Front Load Washer
  • 254 Answers
U must get the inner and outer tub parts, the bearings are actuallly a part of the outer tub assembly,, it is a pain a complete teardown usuallly people just buy a new unit,,, some units had 5yr part warrranties, common bill on a rear bearing install on frontload is usuallyy 600-900 dollars no joke..
Posted on Feb 03, 2010
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
GE Gas Dryer DBSR453GB1WW began squeaking during the most recent drying cycle. We should we try to repair ourselves or get a repair tech?
The squeaking noise is most likely emitting from the drum bearing (key#543). In order to access and replace the drum bearing will require removing the drum. The drum bearing/sleeve is part# WE1M462. I added the instructions on how to remove the drum in the images below. NOTE: Disconnect the power cord from the power source before servicing the dryer.
Jan 13, 2011 | GE DBSR453GBWW Gas Dryer
I have a Frigidaire front load washing machine Model GLTF1670 AS0 which suffered a major drum rattling failure. The Tech would not repair it. Out of spite, we took the drum assembly apart and found that...
If the drum can be replaced for free, your only cost is your own labor! The bearing that you speak of can be replaced by removing the old bearing and taking it to a bearing supply house. There are two bearings--one just in back of the drum and an outer one that is near the drive pulley. If there is bearing damage, it is generally the one nearest the drum. If the shaft of the drum can be put back into the bearings, then try to move the shaft in different directions--it should not move perceptibly. Rotate the shaft, there should be no roughness or sound when turned. I would think that the company would have improved the quality of the drum material if they have had to eat a number of them under warranty. Finally, have you checked the outer drum material near the path of the inner drum--look for any cracking or breaks. Wear areas are usually of no concern. Make sure the seal in front of the bearing has not been damaged. Good luck!
Jan 09, 2011 | Frigidaire ATF6000ES Front Load Washer
Drum bearing has gone on an AEG 72640 washing machine - is it a drum out repair or can it be done with drum in situ ? I can see that the bearings are available no problem. Would any other seals be needed...
These machines are not a quick one to repair, they have 2 bearings (inner and outer) plus a lip seal. you have to completely dismantle the machine to replace the bearings.
Oct 25, 2010 | Washing Machines
Very noisy when the drum rotates
when there is a noise in the spin cycle as you describe the drum bearing is failing. the bearings are fitted to the outer assembly of the drum.if the outer assembly is got to old then to replace the bearing u have to replace the outer tub assembly too. but this is a costly repair.only bearing replacement is not too costly but bearings with outer assembly replacement is a costly repairing. it requires proper tools to disassemble the washer unit and replace the parts. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 19, 2010 | Hotpoint WMA50 Front Load Washer
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
My hotpoint cdt00 tumble dryer makes a loud banging noise on each rotation what is causing this
It is probably a worn rear drum bearing, remove cover of drum shaft, and examine the drum shaft for wear.
Jan 17, 2010 | Hotpoint Dryers
How do I replace bearing on a CTD00 Hotpoint tumble dryer
front bearing on drum felt bearing the whole front has to be removed from machine .. if felt back bearing same applies .. if the plastic drum bearing guides this can be done by removing side panel .... always disconnect from mains before attempting any repair
Jun 11, 2009 | Hotpoint NWXR473EV Dryer
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Kenmore 46462 Front Load Washer Logo
111 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
