Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
My tv no is working
I have a tv sony trinitron xbr Mod kv36xbr800 than no is working and I need find a repair-men close to my house than can come to fix
  • mjcats5 Aug 19, 2008
    the standby lite flashes 7 times. tv will not turn on. I called sony and they said I would have to get repair man. does anyone know what part might be bad and can i fix it myself
  • 62 Answers
Hiii....silvia142
I'm not sure if yuo can find the nearest repairman,where you live/stay ?!
Thank's
[Vrya]
Posted on Feb 19, 2008
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Aug 05, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
What lamp do I need?
The Sony KV36XBR800 is a direct view Tv not a DLP and doesn't have a lamp. The common problem with those units, for what you've described is Ic8002 Sony p/n# 8-759-670-30 is a Mcz3001d Ic located on the D board. I did two of these in the same week about three weeks ago. The suffix (d) isn't important either a MCZ3001 or MCZ3001DB will wrok just fine. What I do is install a footing first and simply plug the new Ic in rather than subject it to all the heat. Also check R8051 (fusible) for open.
Good Luck!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Trinitron XBR Try to turn on but light just
Look for the service manual, it contains the explanation of the flashing light codes, it will tell you what part is faulty.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
