Question about Frigidaire FRS26R4A Side by Side Refrigerator
I have a double wide Frigidaire - the Freezer Temp light is a blinking "E" and the Fresh Food Temp is blinking "F"
  • rlove4215 Feb 03, 2010
    Before the error lights there was a loud noise that seem to be
    coming from the Ice Maker - is it related?
  • 10,515 Answers
You could try Unplugging the Unit for Few minutes, say 30-60 minutes. If you would see the same Error EF, this means that your evaporator fan motor isn't drawing the correct amount of power. You will need to replace your evaporator fan motor which is located inside the freezer behind the back wall.If the Problem persists, more often it is Faulty Power Board. But, Fan Motor is the usual Cause i have seen on most Refrigerators.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
  • 3,037 Answers
This is the famous EF error for Frigidaire. This means that the control board may be going bad. If you unplug the refrigerator for 30 minutes, hopefully it will reset itself. If it doesn't, then it may need a little more time (try a few hours) or the board may need to get replaced. If it resets, then the codes shouldn't appear again. Sometimes the refrigerator just needs to be defrosted when this happens so if after the first 30 minutes, it doesn't reset, then try getting the whole thing defrosted and see if the error code goes away. If it doesn't, then you can order a new board from repairclinic.com which hopefully you won't have to do.
Let me know how this works out for you.
Benjamin
  • Benjamin Patri
    Benjamin Patri Feb 03, 2010
    You would have to narrow down the noise. Is everything working like it should be?
Why is my refrigerator temperature dropping and freezing food, but freezer temp holds.
Hello Michael, I appreciate your inquiry!
Based off the information you have provided your Frigidaire refrigerator is dropping the temperature within the fresh food side. The damper is located within the back of the fresh food side and this part will open and close so that the cold air from the freezer will come into the fresh food side. It is possible that this damper can be stuck open or staying open for too long. Do you notice any frost developing within the freezer? If so, please perform a manual defrost on the refrigerator and you can do that by disconnecting power from it for at least one hour. If there is no frost within the freezer then check to make sure no packages are holding the damper open. You may need to replace the damper or the damper motor and I would recommend having a professional technician out to perform proper replacement repairs. Best of luck! -Matt
Jan 01, 2016 | Frigidaire Gallery GLHS66EJSB Stainless...
It keeps going through a start up process (clicking and the fan come on then off quickly) at first staying steady then getting longer in the start up process.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
Oct 28, 2015 | Frigidaire Refrigerators
What if refrigerator section isn't cold but freezer side is freezing? It is a side by side Frigidaire.
Hey friend, thank you for your inquiry!
I understand that your Frigidaire refrigerator is not cooling within the fresh food side but cooling in the freezer. I would check to assure that the vent assembly is not blocked by any food, if so remove the food and allow your refrigerator to cool down.
If there is no food blocking the vent place your hand in the fresh food side to see if any air is moving out of the damper. If you do not feel air coming out it could be an issue with your evaporator fan. Additionally we should check to make sure the gaskets are not bad. You can do that by using a dollar bill. Place the bill between the body of the fresh food and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. I hope this information has been helpful. - Matt
Oct 12, 2014 | Frigidaire Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
My side by side freezer is working fridge wont get cold,compressor is working.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require a service technician to check and repair these components.
Hope this was helpful. Good Luck.
Aug 29, 2009 | Frigidaire FRS26R4A Side by Side...
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
I have a frigidaire sisde by side refrigerator model # FSC23F7TDW. My Temperature control is reading the the freezer & fresh food temp in centigrade. How do I get the Temp display to read in...
Same Guest as above posting this ... By the way, I have a FLSC238DS5 ... I spent 45 minutes on phone w/Frigidaire this afternoon (Phone#: 706-860-4110 Option 1 --> then Option 3). Didn't get anywhere. They say there are 3 solutions that should change it from C to F: 1) In between LED readouts for "Freezer Temp" and "Fresh Food Temp" there is a mode button that is hidden under the plate that you can press w/your finger OR 2) Hold "Fresh Food Temp" Up Arrow Key down, within 5 Seconds press "Freezer Temp" Up Arrow Key 3 times and it should change C to F or vice verse. Didn't work for me so she said 3rd option was to have a service tech come and diagnose. She said there would be a charge. I am not paying to have somebody come here to resolve this issue. That is when I asked her to escalate it to a supervisor which she did. Hopefully, I get a call back & a solution. Stay tuned ...
May 24, 2008 | Refrigerators
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
289 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
