Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd525 ahs no picture a clicking sound in the tv
Wd52525 has no picture a clicking sound in the tv and a constant green light blinking. I tried to reboot the system and also tried unplugging the tv and nothing is working
  • 4 more comments
  • inthewindfor Feb 03, 2010
    it wont shut down and I dont see a input button
    still blinks then clicks blinking stopss for split second while the click takes place then continues the cycle. I think the fan stopped working . when i hit the reset button i hear the fan start up. when i release the reset button the fan stops and the flashing and clicking starts up again
    I tried the input button DEVICE and menu and nothing happens
    i have to unplug to get the blinking to stop and the green light to go out nothing i do stops that
    by constant green light you mean the fact that it is constantly blinking green light with the clicking sound?
    thanks for your effort on my issues with this tv
  • 10,515 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Let me know the Error Code, so that i could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
  • 3 more comments
  • taran_2005
    taran_2005 Feb 03, 2010
    Thanks for your response!!
    It seems that i might need to Provide you with Diagrammatic Location of the Buttons. But, as of now, On the front of the TV, to the left there is a small hole that you press with a pen to reset the TV, have you done this?
    If not, Reset and let me know the Result.
    Hope i helped you.
    day!!
  • taran_2005
    That's not a Problem.
    On your Model, i guess there would be a Device and Menu Button. Press that and tell me the Series of Blink, like 5 blinks then gap and then 5 blinks.
    Or Green light is ON? Irrespective of the whatever you do?
    Hope i helped you.
    day!!
  • taran_2005
    As you are getting Constant Green Light, there are 8 capacitors total that need replacing.These capacitors are on the DM,FMT board.They have been changed in value by manufacturer.This was done because of constant breakdowns.
    You need to Open the TV and then need to replace those Caps. Those Caps could be Leaked / Swelled or Bulged with Ammonia kind of Odor.
    Note - Even Unplugged, these Units have a lot of Voltage to KILL. So, kindly take all the Precautions before you Replace those.
    Let me know, if needed further assistance.
    Hope i
    helped you.
  • taran_2005
    Clicking Noise usually Refers to Failure of Circuit. It more often confirms that there is an issue with Caps or Cold Soldering . However, you need to Inspect that by Opening the TV. You would need to check for the Bad Caps.As i said, in this Unit there would be 8 Caps but you also need to Check the Fuses and Caps on the Nearby Board to make sure there is no Swollen Cap or Leaked Cap left untouched.
    Hope i helped you.
  • Tom 1234 Dec 25, 2012
    I have a wd525 with only a menu and "device" option. Timer light blinks sequence 10 blinking-pause-10 blinking, before and after pressing sequence outlined above. Any help in 2012 for me, we just moved and replaced lamp last year-don't want to give up on this tv yet! Thanks
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubiushi wd52525 nstatys ligts keeps blinking green. Lost power when the TV was on and now i have a status light that just keeps blinking green.
Unplug for a minute, when pluged back in light should blink for a few then go out, should be able to power on after that!
Dec 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture no sound
it sounds like the chassis has gone bad. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I need the schematic for mitsubishi television wd52525
go to www.blinking-green-light-of-death.com
it shows available.
Nov 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
